Check your setting. If you are taking real high resolution photos you won't be able to store as much on you memory card. Reducing photo resolution will help.
It appears the photos are stored on the internal memory in the camers and this us usually a small memory. You most likely need to insert a large SD memory card in your camera say 8 to 16Gb or more depending upon your requirements..
You will have to delete some photos.
If your current storage is set to memory card, you have to set it to internal memory before deleting photos.
Use the delete function in the camera menu.
It doesn't say the memory is full, it says the frame number is full. Basically you've taken 9999 pictures and it doesn't know what to do with the file name. Look in the setup menu for a frame number reset, or a file number reset. If you can't find either of those, look for a general purpose reset function - it's usually right at the bottom near the card formatting function because you hardly ever use it.
You will have to manage the situation that you will now have duplicate file names, since it will start numbering from 0001 again. I suggest you archive all your current photos, and start anew somehow.
try to delete some pictures, recordings and videos, sometimes the reason why it has a message like that is because the memory of your cp is already full
Try to format the memory. Go to the menu to setup option and press ok. Go to memory format and press ok. You will see format yes or no. Choose Yes and press ok. This will permanently erase all images from the memory and will solve the issue of the camera always reading memory full.
Thanks! Has no card, but formatted the memory and it worked.
