Question about Athena AS-P4000 Subwoofer
Dead Athena AS-P400 subwoofer
Working fine one day and nothing the next day. The red "standby" light does not even come on now. Double checked the wall jack to make sure the power was on.
  • volzbrian Sep 01, 2010
    Did you ever get it working? I am having the same problem.
I have a pair of athena p3c1 subwoofers. the problem i have is that no sound is comeing from them but the power light is on. they both stopped working at the same time. i have had the subs out to check for...
Don't understand why 2 subwoofers?
As a tech my attention is drawn to what you said-they both stopped at the same time,have you checked the signal from the source--ie- disk player ,tv,etc
Try plugging something else into the subs separately
if still no go have you got access to the speaker cones?
if yes then place your ear close to the cone and move the cone down and up evenly with your fingers
If you hear a rasping sound the voice coils are blown
if all is clear check the speaker fuses on the amplifier boards
If you have a multimeter set it to low ohms,the reading should be 4 or 8 ohms .you can check this on the speaker label
make sure you disconnect one speaker terminal before testing or the amp output capacitor will affect the reading
Hope this helps
Len
Oct 20, 2017 | Athena P3 Speaker
When I turn on my PS3, the sony music begins and the orange sony wave screen turns on but it doesn't move on to the menu. I have shut the system af by turning off the button at the back of the PS3, I have...
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Lights on, motor running, does not do single/double shots
There is a tiny plastic one-way valve in the brass tube on the pump under the top cover that get calcified and stuck when not in use. I used a toothpick to get it out after disassembling the pump and its hoses. Slowly and carefully lay out your parts to reassemble the springs and washers correctly.
Oct 14, 2009 | Estro Barista Athena
Red standby light does not come on
a black fuse means really excess current.if it is the ac mains fuse be careful.i am is 120 watts of power different.if it is the dc fuse,try a slow blow fuse with the same rating. it will allow more dynamics from movies ect.
Jun 12, 2009 | Athena AS-P4000 Subwoofer
Monitor has just stopped working
perhaps a repair shop. most electronic devices fail this way
Oct 06, 2017 | Hanns.G Corporation HX191DP LCD Monitor
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
Jensen JS1000-A sub stopped working, why?
Is is possible that the receiver's subwoofer configuration turned off? double check your speakers setup in the receiver...Just an idea.
Jun 30, 2007 | Jensen JS1000-A Subwoofer
TV will not turn on
check the items listed in the image to locate the 5 blink error. good luck.
Jan 03, 2007 | Sony KV-36FS16 36" TV
Athena AS-P4000 Subwoofer Logo
168 people viewed this question
Top Athena Audio Players & Recorders Experts
Eric Sutherland
Len Dipper
Len Dipper
Are you an Athena Audio Player and Recorder Expert? Answer questions, earn points and help others
