Question about Vivitar DVR-550 DV Camcorder
Re charge the battery
DVR 550 user's manual do not explain how to re charge the battery, do I need a special charger????? what model and the cost.
thank you....
  • 13,433 Answers
if the camcorder came only with a usb cable and no charger, it most likely charges from the usb connection, my phone does this also, just plug it in usb and it charges.
Posted on Dec 17, 2008
    Top Expert:
  • Vivitar Master
  • 81,285 Answers
Yes u need the charger for the battery, no camcorder has a built in charger.
  • Marvin
    Marvin Dec 17, 2008
    the charger will be specific to your model camcorder, go to Vivitar web site you will find it there.
  • Marvin
    Marvin Dec 17, 2008
    It may be correct about the USB method, check the owners manual but I don't recommend this method, slow and u must run the PC all the time.
How can i charge my Vivitar 550 camcorder without original charger? (Currently in remote part of Afghanistan)
Look for a ,,Universal Battery Charger" like those ,,made in China" remove your battery pack from camcorder, and insert them in the charger. The charger is inexpensive and very useful, having two adjustable flexible contacts that fits to every possible battery used in cellphones, cameras and camcorders.In my country Romania, this universal charger cost about 5 dollars or 4 Euros.
Sep 09, 2010 | Vivitar DVR-550 DV Camcorder
How do you recharge camera battery? camera manual is not clear abot how to hook up battery charger or even where it is!
The easiest way is by using a standard USB cable...plug the small end of the USB cable into your camera (located under the headphone jack) then plug the larger end of the USB cable into your PC or laptop. Turn on your computer & this will charge up your Vivitar 550.
Dec 27, 2009 | Vivitar DVR-550 DV Camcorder
Replacement power cable required to charge vivitar dvr 550 camcor
Hi Trevor
From what you describe it sounds like you just need a mini USB type charger, readily available off ebay, heres one for instance http://cgi.ebay.co.uk/HTC-Mobile-Phone-New-Mini-USB-Mains-House-Charger_W0QQitemZ350254239595QQcmdZViewItemQQptZUK_MobilePhones_MobilePhoneAccessories_MobilePhoneChargers?hash=item518cc78f6b.
There are also USB to mini USB chargers available and in car too, all 5v output.
Hope that helps you.
Seadsons greetings to you
Bob
Dec 26, 2009 | Vivitar DVR-550 DV Camcorder
Hi I,have a Vivitar DVR550,and need a new recharger for it. when I,but when I,put my model in the vivitar support page it does not have the model number in the list.There is nothing wrong with my camera...
Go here:
http://www.amazon.com/VIVITAR-DVR-545-DVR-550-DVR-550G-CAMCORDER/dp/B002RN6DO0/ref=sr_1_64?ie=UTF8&s=photo&qid=1260903217&sr=1-64
You can read the specs of exactly what type of charger is needed, or just purchase it.
Vivitar DVR 550 was a well known model in the UK. but the company Sakar bought the Vivitar comapany out. However, the Vivitar site still exists, but not much support for the DVR 550 is provided. I would recommend e-amiling them by visiting www.vivitar.com
Good Luck
Nov 26, 2009 | Vivitar DVR-550 DV Camcorder
Vivitar dvr550 battery charger
Try Sunny Technology Co Inc
Model SYS 1193 1005 W2
It appears to be a universal cell phone charger.
Hope this helps.
Jul 26, 2008 | Vivitar DVR-550 DV Camcorder
Vivitar DVR 545 - Is this going to work with my MacBook?
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
RE-INSERT THE BATTERY INTO THE CAMERA.
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
You will destroy your DVR 545 in seconds!!!!
Jul 09, 2008 | Cameras
Vivitar DVR 550 5 in 1 camers/video recorder
I use my motorola cell phone charger....they're interchangable
Mar 19, 2008 | Vivitar DVR 530 Flash Media Camcorder
Vivitar DVR 550 camera not working.
I had the same problem and purchased a new battery to resolve the problem. I also purchased a 110v battery charger for the vivitar 550 camera and recharged to old battery.
Dec 30, 2007 | Vivitar DVR 530 Flash Media Camcorder
Vivitar DVR-550 DV Camcorder Logo
26 people viewed this question
Top Vivitar Video Cameras Experts
Joseph Wright
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
