Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash drive can not be detected when installed on a desktop with an XP operating system. flash drive is recognized on several other desktops with XP, but not my computer. is it a driver issue? if so, can you list a site i can find drivers for kingston flash drives?
  • Anonymous Dec 25, 2008
    sir my pan drive is not working
  • 33 Answers
Hi john_nelson0,
First check the other USB ports. Try it in the USB ports on the back of the computer. If that doesn't help then make sure you have the latest WinXP service pack installed. Although it is possible to have a problem with the drivers, they are built into Windows and are not available for download from Kingston. Do any other USB drivers work on that computer?
Kingston Tech Support
Posted on Dec 29, 2008
Cant get to desktop cause I cant remenber passwords, on Dell Vastro 1000
What I usually do is re-enstall the operating system. Set your BIOS to boot from the CD drive with the first re-boot set your BIOS to boot from the hard drive. If your BIOS allows it you can also boot from a flash drive. What I've been doing for the last decade or so is partition my main hard drive in several partitions, having the windows install (along with all my other software and drivers) on a different partition than the operating system. This way after you reformat your c: drive all your important files are protected and available on another partition and if there no operating system disk or flash drive, you can always install from DOS.
Dec 11, 2012 | Computers & Internet
My flash dive is not work pc is not recognize it
Windows XP, Vista , or Windows 7 should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
If you have an older operating system then go here to download the driver:
http://www.sandisk.com/sandisk-support/driver-download-wizard
May 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
XP will not reinstall
please press f2 and go to bio and set a default bio and install windows
May 07, 2012 | Dell OptiPlex GX520 PC Desktop
Susytem cannot detect the video card
Ok, in this case it is wise to check on "device manager" in your operative system. Click on "control panel" then click on the icon "System" then select the "Hardwaref" then open "Device Manager". See if theres any yellow flag indicating that there's a device that is not recognized. Since you seemed to have some knowledge, did u try runing the graphix card on safe mode (pressing the "F8" key several times while bios is booting up") and, was then it recognized?. If you've done all that already, the easiest way to discard any problem is installing the same graphix card in a different computer or borrow one from a friend and see if it works. Good luck.
Jan 03, 2010 | Microsoft Windows XP Professional
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Kingston 4GB Data Traveler USB 2.0 flash drive not recognized by eMachines T1090 with Windows XP Home Edition. Says it needs a driver????
probably,the driver was not installed by default.
1. launch the flash drive web site and download the driver for flash drive.
2. test the flash drive with windows xp service pack 2 operating system,if it works without a driver. then providing a driver for your window will do.or upgrade the os
Apr 20, 2008 | Computers & Internet
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Flash drive
Hi phun2008
Did your question get answered? (I'm not sure what "no thanks" was in response to.)
Your flash drives should work fine w/ Windows XP. They should be detected by the operating system as mass storage devices - plug-n-play - w/ no need for drivers installtion, etc.
You may, however, experience detection issues w/ them on systems w/ older USB hardware. If the flash drives are USB 2.0 drives, they will not be detected on systems running USB 1.1 or earlier - regardless of the OS (operating system) installed.
On the other hand, if they are USB 1.1 flash drives, they should be detected fine on both older and newer USB ports as USB 2.0 is "backward compatible".
I hope this helps.
BJ
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
119 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
