Question about Ovens
I need a wiring diagram for the circuit board to a Whirlpool RM770PXBQ2 wall oven. Can you help?
    President:
  • 2,651 Answers
Loks like to be a an older, micro/oven combo unit. too old to even have a tech sheet available any more,althought i can lookup the techsheet its nothing more than a wire diagram for the unit and a quick troubleshooter, no real breakdown for diagnosing hte circut board itself, hers alink to what i found good luck. there may be a copy of this within the control cavity as well
http://www.servicematters.com/docs/wiring/wiring_main.htm
Posted on Dec 17, 2008
Whirlpool oven Super Capacity 465 error F3E1
The F3 E1 error indicates a problem with the oven temperature sensor or a short in the oven temperature circuit. To trouble-shoot this error, unplug the oven. Check the wiring harness for damage and then reconnect it, if it is undamaged. Next check the resistance across the oven temperature sensor. The resistance should be 1080 Ohms at room temperature. Replace the sensor of the resistance is not correct. Otherwise replace the main control board.
Please add a comment with the model of your oven if you want me to look up the parts list or diagram for your appliance.
I hope this helps.
Aug 05, 2017 | Whirlpool Ovens
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
Error code F3 after self cleaning
F3 means that the oven temperature sensor has a open circuit. Check connection from sensor to the control board. If connection is good, replace oven temperature sensor. Hopefully the wires are long enough, then you can unscrew oven sensor and pull the connector thru hole to check connection and to replace. If its not long enough, you will have to remove oven from wall to check
Feb 13, 2011 | Whirlpool RBD305PD Electric Double Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Stove shuts off and posts F10 on readout
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool wall oven model rbs245pdq12
Adjusting circuit board settings for oven size.
Apr 27, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven door won't unlock
There is a high limit safety thermostat that acts as a one time fuse. If the outside of the oven gets too hot it will shut down power to the elements. The safety is on the behind the back wall of the oven (depending upon the model) the wall oven will have to be pulled from the wall and the back cover removed. Be sure to shut off the circuit breaker before removing the back cover. The thermo fuse should be located slightly to the right and up from the convection fan port. The door will unlock once the power is restored to the circuit. There should be a wiring diagram inside the top control area of the oven that will help your efforts.
Mar 12, 2007 | Kenmore 47813 Electric Double Oven
Ovens Logo
154 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
