Question about Sony KP-61HS10 61" Rear Projection Television
I have a Sony KP-61HS10 that will not turn on.....
All I get is the red timer/standby light flashing constantly.
  • arorafamily Dec 26, 2008
    The standby light flashes five times. pasues and then flashes agin. Sound is fine from all input sources but no picture on any setting or input source.
  • Anonymous Jan 07, 2009
    Tv works fine for 10 Minutes the the standby light flashes five times. picture goes out. The standby pasues and then flashes again. Sound is fine from all input sources but no picture on any setting or input source.
Hello read my comment on shadie333 i just posted the problem i had, my tv is a kdp65ws550 which is also the same as the kdp57ws550 and kdp51ws550 mine was doing the same thing... ours is fixed... please read it
Posted on Dec 17, 2008
STANDBY TIMER IS A CONSTANT FLASHING
This older model the light should blink at turn on for 10-15 seconds before picture appears.
The set is checking for certain voltages and other things---if any are missing it will not come up.
This is like saying car will not start--the Battery? Or?
Someone would have to go inside and check voltages first and then check to see if horz or vertical drive etc.
May be too old a set as some parts for it no longer available.
Mar 19, 2012 | Sony KP-41T65 41" Rear Projection...
Red light on TV is flashing 5 times and the picture is blurry and shadowy
That usually means poor emmision on one of the tubes or an EHT fault.
The AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Hope that points you in the general direction.
Feb 20, 2011 | Sony KP-61HS10 61" Rear Projection...
I have a Sony KP-61HS10 and I replaced both of the CI's and the Pico fuses and when I plugged it back in all I get is a red flashing power light, what happened?
This is unfair! You said you have to go out and thats why you have closed the session, and for that you give me a bad rating in the live chat! That was really rude!
Dec 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
When t.v. is turned on, black picture and no sound.
Usually when the fuse blows its due to a component being shorted and if you increase the rating of the fuse you can cause other components in the circuit to blow. The pop you hear was most like a capacitor on the D board. The D board is no longer available from sony as its listed as discontinued. You will most likely have to have a qualified sony service tech trouble shoot the circuits on the D board to locate the short as it will be outside the scope of a do it yourself type of repair
May 16, 2008 | Sony KP-61HS10 61" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-61HS10 blinking codes
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
You can get the service manual and free support at the following site to help yu with the repair of your sony the manual is 10.99 support is free here is the link. They will email the manual to you.
http://servicemanuals.vstore.ca/
Feb 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
506 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
