Question about Dell 948 All-In-One InkJet Printer
My Dell 948 prints VERY slowly.
I had a virus over the summer that I finally was able to remove. However, upon removal of the virus I was left with a new problem (and I'm not even sure if they are related) and that is my printer works incredibly slowly. By that I mean, it is a 2 minute wait for one page to print, and multiple page documents won't even work. Nor can I print Adobe docs or pdf docs either. I have checked spool settings, removed the software and reinstalled it. I have unplugged all cords and rebooted the printer a zillion times. I have tried every tech tip I could find...to no avail.
Suggestions would be great.
Brad
  • 1 more comment
  • braddorsey Dec 17, 2008
    I have tried and re-tried all of these suggestions...as I stated in my first post. I re-tried them again, per your direction, and still no improvement.
    I need further direction...please.
    Brad
  • braddorsey Dec 19, 2008
    That didn't work either. If I buy a new printer can this same problem continue? Or will a new printer and software fix it. I am willing to buy a whole new printer just so I don't have to wait sooooooo long for my printing.
  • braddorsey Dec 22, 2008
    No warnings or errors related to printing in the event viewer.
  • 2,427 Answers
Hmm it could be one of the drivers was corrupted by the virus or antivirus (yes it happens)...
Try this
1.) unplug the printers usb cable from the computer
2.) right click on my computer click properties then device manager
3.) right click anywhere in device manager and scan for new hardware changes
4.) restart
5.) right click on my computer click properties then device manager
6.) right click anywhere in device manager and scan for new hardware changes
7.) click start then printers and faxes
8.) click the printer icon and press delete
9.) plug the cable back in in a different usb port
10) the computer will detect and reinstall the printer as a new printer and that will solve all your problems
incase it doesnt happen automatically do steps 2 and 3 ..
Posted on Dec 28, 2008
  • Dell Master
  • 19,396 Answers
There are only to reasons for the printer taking a long time to print and eject the page, a fault/system problem, or incorrect resolution settings.
To start enable the spooler again, and before printing go to printer settings and lower down the printou resolution.
If this does not fix it, you test printer on a different computer, if printer is OK, reinstall Windows on first computer.
The most likely is always incorrect resolution settings.
Posted on Dec 27, 2008
  • 679 Answers
Try this first, get into the device manager, start, settings, devicemanager, system, hardware,device manager, will see all your printer listed, you may see more than 1, highlight all printers and un install, on a restart it will say found new hardware and ask you if you have the disk, put in the disk and re install the drivers and you should be good to go, it's going to fix any conflict that may have been caused by the virus removing or corrupting your file system, good luck
Posted on Dec 24, 2008
    Brigadier General:
  • 5,158 Answers
I would suggest it is something along the lines of not enough memory... a possible incorrect driver... or spyware + too many programs running at one time. spyware is fairly easily fixed. download a program called spybot s&d. install it and update it then perform a scan.... defrag your computer as well. after you have done that if there is no marked improvement i'll explain how to reduce the amount of program that run at start up.
Robert
Posted on Dec 23, 2008
  • Dell Master
  • 6,487 Answers
A new printer will make everything here work, because we're not sure if this problem is really related to the printer not to your computer system....
Posted on Dec 22, 2008
    Genius:
  • 1,142 Answers
You need to remove the software then restart the computer switch off the printer and then turn it back on then reinstall the software that will take care of the issue.
  • 1,879 Answers
Additional troubleshooting:
>by-pass Spool - Printer Properties -> Advance tab - options to play with, print direct & disable advance printing features
>Spool makes temporary files for print jobs - clear $:\WINDOWS\System32\spool\PRINTERS directory
>after printer driver uninstall - clear $:\WINDOWS\System32\spool\DRIVERS\ or via (Printers & Faxes -> File -> Server Properties -> Drivers tab)
else;
virus made a big mess
back up personal data
re-install windows
getting a new printer wont make the issue go away
Posted on Dec 19, 2008
  • 162 Answers
Windows version XP or Vista ? Anti-Virus software installed ? Installing the printer on another computer produces the same result ?
  • 10,594 Answers
I'm sure, virus is still in your PC and disturbing the function of printer software / driver.
Once I had virus in my PC, installed many anti virus software, updated, but non of them worked and at last I have had to format HDD and reinstalled Windows, drivers etc.
I would recommend to take backup of necessary files, format HDD through Sea-gate hard disk utility (I used it), create new partitions, reinstall Windows, drivers etc
    Genius:
  • 1,199 Answers
Defrag system then download printer softwaes again
and that should fix it!
    Guru:
  • 449 Answers
Try to back date your computer or reboot it. hope this help
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls download, install and run AdAware. Run in Normal and Safe Mode. List down file(s) it would find/quarantine in the C:Windows. After it has scanned/cleaned in Safe Mode, run regedit. Find all references to those files that you listed. Delete those registry entries. Safe Practice dictates that you backup your registry and should be comfortable working with registry modifications.
Of course, the best would be to do a complete clean, fresh install of the OS.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 17, 2008
  • 124 Answers
Let's try this. Send a doc to the printer.
Open up Event Viewer (Start->Run, type eventvwr)
Under either System or Applications, see if there is any warning or error relating to the printer.
Let's go from there.
  • 48 Answers
Just for kicks i would try using a different connection to your computer. If you use USB then try the parallel port or visa versa.
  • Dell Master
  • 13,433 Answers
Hi
Few things to check start -> run -> type in services.msc make sure service named as printer spooler is started, if not right click properties startup type automatic and start, close window.
Check the printing preferences, check quality set it to normal. Check that the printer is set to use the print spooler.
It might be easyer to reinstall the printer, so remove the printer software from the computer, install the software and drivers again.
My black cartridge was running low but was still printing. Then I got the Cartridge error message and to consult my user guide. I have misplaced the booklet. I replaced the black ink cartridge and...
Welcome to Fixya. If you lost the user guide on how to fix the error perhaps the link below will help you out your problem. It contains solution on how to fix cartridge error and the proper way to replace cartridge.
Dell AIO 948 Troubleshooting
Thanks
Jun 17, 2011 | Dell 948 All-In-One InkJet Printer
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
Ihave a dellp513w and some how i put the disc in that came with it trying to get it connected to the computer so i'am able to print from the computetr and it want work. The disc want connect to the...
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Uninstall the printer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
With your computer online, Insert the printer disk or try using the drivers located at...
Dell P513w Wireless All-In-One Printer owners thread
You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block printer communications.
Rick
Apr 19, 2011 | Dell 948 All-In-One InkJet Printer
There is a document in the queue that will not print or cancel. It is stuck and will not allow me to do anything else. I have turned off, unplugged and disconnected the printer from everything to no...
Have you searched along the task bar for the printer icon? Right click on this and it should present a list of documents for printing. Highlight the one you want to get rid of and then use the options to delete. Next try using Task Manager to get rid of the task. Finally remove the printer from your hardware in the Control Panel and re-instal. Hope this helps.
Jan 25, 2011 | Dell 948 All-In-One InkJet Printer
Paper jam
Here are some useful steps you can try:
try to power cycle the printer for about 2 mins. then try a test print with just single paper
Make sure that the paper is aligned properly.
You can also check if there's any foreign object stuck inside the printer
If you are able to reach the paper roller on the printer, try cleaning it.
Lastly turn off you printer, try to lift your printer up, put it in an upside down position
then shake it from left to right for about a min. then turn the printer on again
try a test print.
If none of this steps resolved the problem
then the issue is with the printer itself.
Hope this helps.
May 16, 2010 | Dell 948 All-In-One InkJet Printer
My dell all in one 948 printer always have low black ink. After I put in a new black ink and after five prints the indicator said low black ink. Please provide a solution.
The ink sensor is malfunctioning, make sure the area it plugs into(contacts and ink port is not dirty fouled or clogged up and that any plastic or strips are removed that are supposed to be removed, a cotton swab dipped in alcohol goes a long way with printer problems. make sure its unplugged and hold the power button down for a few seconds before touching any sensors for safety even unplugged machines can hold a charge in them.
Jan 14, 2010 | Dell 948 All-In-One InkJet Printer
Dell 948 printer. Black(2 inch) Vertical lines when I print
You need to check the glass for any white-out or other smears that don't belong, if the glass is clean then the scan assembly has elements that are burned out which will cause dark streaks.
Jun 30, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer- won't print in black and white
I had this problem. It's actually very easy to fix:
- Click Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Feb 05, 2009 | Dell 948 All-In-One InkJet Printer
Printer 948 false paper jam
Tonight, I fixed my neighbor's Dell 948 printer with false paper jam.
After you lift open the top, look below the shiny bar that the Print Head slides left/right on. You'll see a row of 8 tiny rollers. In between the middle two rollers (rollers #4 and #5 from the left), look for a small plastic tab sticking up between them. Touch this tab with the tip of a ball-point pen to see if it pushes down. If it does, then push the "checkmark" button on the control panel.
That's what I did to fix my neighbor's printer.
Sincerely,
John
Jan 05, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
Dell 948 All-In-One InkJet Printer Logo
116 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
