Since i washed my keyboard with water is been acting weired.when i press spacebar it turns out enter so i have to hold ctrl before it becomes space why?
  • 34 Answers
How expensive was this keyboard.?
What has probably happened is that fluid got onto the keyboard membrane/matrix. This causes the membrane/matrix to stick together. You may be able to solve the issue by stripping the keyboard down and cleaning the membrane/matrix ( a simple enough job)
Or alternatively buy another keyboard - they're cheap enough these days.
Posted on Dec 17, 2008
  • 5,568 Answers
Common keyboards are nothing but a bunch of switches and the currents that flow inside of keyboard are very small. If you 'washed' it as you stated, you have probably gotten moisture into it along with some contaminents you wanted to remove and it is causing currents to flow where they shouldn't.
Don't do this to your next keyboard; if you want to clean it, use a dampened clean paint brush followed immediately by a clean towel.
Never put liquid anything on these, they aren't designed for use while snorkeling.
Standard keyboards cost <$20 and I have gotten them free after rebate so you can shop these pretty well.
Why does my delete key act like a spacebar?
There are a couple options:
1. Your keyboard is broken, you need to replace it.
2. Try unplugging / replugging it un and or restarting your computer, that may fix the issue.
3. Your keyboard layout might have changed. If you are using a Windows computer, you can press CTRL + SHIFT to switch between layouts. Or you can go to Control Panel -> Clock, Language, and Region -> Change Keyboards or other input methods. From here, you can change your keyboard layout back to use.
Jul 23, 2014 | Toshiba Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
How to turn on my keyboard back light
If the spacebar has a keyboard icon on the left side, press and hold the Function key (Fn) and then tap the space bar one time. Press the F12 key. Press the F5 key. Press the special key dedicated to turning the back light on and off.
Oct 24, 2013 | Lenovo IdeaPad Y410p Laptop Computer -...
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
I am unable to open my cd drives with the keyboard
On your keyboard:
Press the Windows key.
Use the keyboard arrows to navigate to the My Computer icon, and to highlight it.
Press the Enter key.
Press the Tab key, repeatedly, to highlight the icon for the CD-drive.
Look on the bottom-right of your keyboard:
SPACEBAR, ALT, WINDOWS, other, CTRL
Press that "other" key.
Use the keyboard arrows to highlight EJECT.
Press Enter to "open" the CD-drive, and to "eject" the CD.
Feb 12, 2011 | Packard Bell 5121 (120159) Keyboard
Running a lenovo G550 with Windows 7. Games, including flash games, do not respond to my any of the letter keys on my keyboard unless I am holding down CTRL. All other keys (shift, spacebar, enter,...
sounds like you have engaged crtl lock on your keyboard - not sure of the keyboard layout you have buy somewhere on it is a key with crtl lck on it -press that and the problem will be resolved.
Dec 14, 2010 | Lenovo G550 PC Notebook
When i press spacebar my search results page appears
Keyboard replacement solved the problem. In my case it was a faulty Logitech keyboard. It seems that Spacebar is acting as F3 and Space the same time.
Feb 04, 2010 | Logitech 967437-0403 Keyboard
Which 3 buttons are directly left of the spacebar?
Most Compaqs have the following to the left of the space bar:
Ctrl - Fn - Win Symbol - Alt
However some have this layout:
Ctrl - Win Symbol - Alt - Fn
If you post the model # we could say for sure.
Thanks for using Fixya.
Jun 24, 2009 | Compaq Keyboard
Pressing spacebar once will make cursor skip 3-5 spaces
I had the same problem on the Logitech MX3200 wireless keyboad. I simply unplugged my receiver from the USB port and plugged it back in. It's not the first time I've had this happen
Jan 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
My keyboard is inserting spaces where they don't belong.  it is usually around R's, N's and spaces (I  press the   spacebar once it it inserts 2 or three spaces, the  faster I type the   worse it gets.)...
You should open the key board.and clean space key and change rubber cap.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Logitech 967437-0403 Keyboard
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
