I can bake cookies just fine in an electric oven at the degrees that is according to the recipes but I cannot bake cookies in my gas oven. They burn on the bottom and are not done on top. It is just a waste of time and frustrates me to no end. I really need to know how to bake successfully on this Whirlpool gas range. I sincerely hope that someone out there can tell me how to bake in this gas oven.
First, I would buy an oven thermometer to use in the gas oven to see if the temp you set is what you are getting. Second, Perhaps, you used a different pan or cookie sheet in one vs the other? Also the cookies perhaps should be a little closer together as they bake. A cookie sheet with a lot of uncovered surface will get hotter than one with a bigger load. (ever notice the instructions for biscuits or cinnamon rolls say "sides touching"?, same reasoning. if you put a few rolls on a big sheet or pan, you'll burn the bottoms, gas or electric.) Hope this works for you, when you get happy using the gas, you won't want an electric again.
Look at the Moms Who Think site - I
think they have enough cookie recipes to keep you busy for a while.
http://www.momswhothink.com/cookie-recipes/cookie-recipes.html
Thank you for your suggestions. I did get the cookies baked and they turned out pretty good. I decided to put the cookies close together and I put another cookie sheet the same size underneath the one with the cookies on it. The cookies did not burn on the bottoms and the tops got done also and I baked them at the temperature required.(375)
I have the same problem except I am using an oven in an RV. Any suggestions?
whirlpool gas range, need manual , do not know how to start oven.
