Question about Maytag Dryers
Dryer Drum Won't Spin
I have a Maytag Washer/Dryer combination which is about 16 years old - Model # LSE7800ACW. When I turn the dryer on, it heats, but the drum won't turn. What could be the problem?
Thanks for your help.
  • 113 Answers
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Posted on Dec 17, 2008
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Maytag Dryer - runs but no heat
it needs a new element behind the drum
Sep 19, 2009 | Dryers
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a maytag stackable washer dryer model number LSE7800ACW when i turn on the washer it will not fill it will not spin it will not do anything but the dryer works just fine. What is wrong
HI. thanks for the question. you have a blown fuse ,inside the washer. remove the front panel. on the left ,you will find a small glass fuse .check that. if its failed you will be able to see, that the small metal strip inside the fuse is broken , if so replace the fuse. thanks the appliance doc . please rate my answer.
Oct 07, 2008 | Maytag Washing Machines
Maytag lse7800acw
The motor is faulty. Either the relay contacts are stuck or there is a shorted winding. Best to replace the motor.
Jan 13, 2008 | Washing Machines
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
282 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
