Question about Alpine MRP-M350 Car Audio Amplifier
Amp gets power but doesnt send anything through speaker wire
The bolt that hooks the ground wire into the battery is stripped it could be intermitting power to the amp but the amp is still getting power just not sending any and none of the fuses are blown should i try a new battery
    Problem Solver:
  • 14 Answers
There are several things that could cause this that i know of, bad ground not being one of them.
A bad ground terminal should cause a noticeable distortion in sound and cause the amplifier to turn on and off.
If you are getting power and no sound, the first and easiest thing i would check is your RCA wires. Replace them with known good wires.
If that does not work, are you positive the speakers you have hooked up to your amplifier are not blown?
If available, use a DVOM to check resistances on the coils on your speakers. An open lead reading indicates a blown voice coil.
Also make sure that your speakers are each hooked up to a positive and negative terminal, as some amplifiers have two positives next to each other and two negatives, while others go + - + -.
Your amplifier could also have bad input or outputs, but i would try these other easy fixes before resorting to buying a replacement amplifier.
The only other cause to my knowledge would be bad RCA outputs on your head unit.
If possible try with a head unit you know the outputs work on.
Hopefully one of these suggestions solves your problem.
Posted on Dec 17, 2008
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
How do you connect the amp with the stereo
  • Choose where to put your new amp. If you are installing subwoofers it's usually best to put the amplifier in the trunk next to or attached to your subwoofer enclosure. If you are going to power your main car speakers with the amplifier then it may be better to put the amp under the passenger's seat.
  • 2
    Purchase the following wiring for the amp: A thick power cable (the thickness required depends on the total wattage of your amp, ask a sales rep or consult your amplifier's manual for the proper gauge) that will have to reach from your battery to the amp (the power cable should also have an inline fuse to protect the amplifier); 3 feet of ground cable of equal thickness as the power cable; an RCA signal cable to carry the left and right signals from your head unit to the amp; a "remote on" wire which can be any thin wire (20 to 24 gauge) that will also run from the head unit to the amp; speaker wire (if you are powering subwoofers you should only need about 3 feet of 12-gauge wire per sub, if you're going to power your main speakers you will need enough 16-gauge wire to reach each speaker from the amp, 12 feet per speaker is usually safe).
  • 3
    Gather the following tools: Screwdrivers, wire cutters, wire strippers, pliers, a utility knife, sandpaper, masking tape with a pen for labeling, 2 crimp-on o-ring ends for the power and ground cables. If you're hooking the amp to your speakers, you'll also need 2 crimp-on female spade connectors for each speaker.
  • 4
    Find a manual with instructions on taking off the dash of your car (not the whole dash--just the head unit, in order to hook wires to the back), and also to get at your car's speakers if you are hooking the amp to them.
    The Installation
  • 1
    Disconnect the ground (negative) cable from your battery. Never work on the electrical system of your car with this connected.
  • 2
    Attach the side with the fuse of the thick positive (+/red) power cable to the connector on the positive terminal of your battery; the o-ring can be sandwiched in the bolt on the connector that connects your car to the battery. Now put the fuse in the fuse holder.
  • 3
    Run the power cable through the firewall of your car (there is usually an opening on the driver's side) and to your amplifier. If your amp is in the back it is usually best to run this wire under the plastic molding that goes along the bottom edge of your car. Be careful where you run the wire because the power cables should never be near the signal or speaker wires.
  • 4
    Find a metal bolt or screw on the metal of your car near the amp to connect the ground cable to. This should be as close to the amp as possible, never more than 3 feet. Unscrew it and clean the metal surface with sandpaper. Attach the ground to it with the o-ring and screw it back down firmly.
  • 5
    Remove your head unit and run the signal and remote on wires from behind the head unit to your amp. Connect the RCA connectors and the remote on wire to the back of your head unit.
  • 6
    (If you are installing subwoofers and not running your normal speakers off the amplifier skip to step 7.) Run the 16-gauge wire from each one of your speakers to the amplifier. On the amp side use the masking tape to label each wire so you know which speaker it is. On the speaker end-strip a 1/4 inch off the ends of the wires and crimp on the female spade connectors with your pliers. Connect the spade connectors to your speakers making sure to match the positive (+/red or white) with the positive terminal and the negative (-/black) with the negative one.
  • 7
    Connect everything to your amplifier. Only strip off as much as you need off the end of each wire to make a solid connection, you don't want any exposed wire hanging out. If you have subs, attach them to the amp with the 12-gauge speaker wire.
  • 8
    Secure your amp to something. If it is in the back you can screw it directly to your subwoofer enclosure. If it is under a seat you may just want to get some straps that hold it down.
  • 9
    Reconnect your car's negative cable to the battery. Test your system and make sure everything works, going around to see that every speaker is on before you put everything back together
  • Feb 17, 2011 | Car Audio & Video
    I've bought an adapter thing, but I don't understand how to wire these wires.
    • Yellow - To the car battery of continuous +12VDC
    • Red - To ACC Power, +12VDC
    • Black - Ground, to bare metal or clean part of the car
    • Dark Blue - Motor Relay control lead for Antenna
    • Dark Blue / White Strip - Amp Relay Control lead
    • White - Front/Left Positive Speaker
    • White / Black Strip - Front/Left Ground Speaker
    • Gray - Front/Right Positive Speaker
    • Gray / Black Strip - Front/Right Ground Speaker
    • Green - Rear/Left Ground Speaker
    • Green / Black Strip - Rear/Left Ground Speaker
    • Violet - Rear/Right Positive Speaker
    • Violet / Black Strip - Rear/Right Ground Speaker
    Nov 11, 2010 | Panasonic CQ-DP133U CD Player
    I plug in rockwood detanator VII and it goes to protections mode
    Generally if an amp goes straight into protection, the amp is not grounded well enough. Either you should find a new location to ground the amp to or unhook the power wire from the battery, remove the ground wire from the chassis of your vehicle. Strip the paint from the chassis, since it doesn't conduct electricity, and remove any corrosion or copper shielding from the ground connector. reground to a solid metal location Can be grounded to the brace behind the back seat or to the seat belt bolt for best results.
    An amp draws a lot of power, there it needs to be grounded well.
    Hook back up your power wire to the battery and see if your issue is resolved.
    Jul 18, 2010 | Car Audio & Video
    My amp turns on but stay in protect mode
    check your wiring, is it properly grounded? is your remote positive wired to your ignition's positive line?
    Jun 10, 2010 | Car Audio & Video
    The amp turns on but doesnt put sound out
    Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Send back ri factory for best repairs.
    A thumbs up would be greatly appreciated if this answer is helpful to you.
    Mar 05, 2010 | Hifonics BXi1608D Car Amp
    Amplifier turns on but not the subwoofer?
    Hello thedj3214,
    You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
    You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
    The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
    A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
    Hope this helps.
    Jul 28, 2009 | Sony XM-2150GSX Car Audio Amplifier
    How do i intall my amp?
    first you need to run a power cable for the battery to where ever you are going to place the amp DO NOT hook the cable to the battery until the very last just wire it to the amp for now.next you will want to ground your amp hook the ground wire to the amp and the other end to a solid piece of metal in the car this is very important if you don't get good metal on metal contact you'll blow a fuse. If you can hide it well strip back a bit of carpeting and use sand paper to remove all paint from the metal and drill a hole for a screw. once that is finished you will need to run a remote wire from the amp to the car stereo usually these are the blue wire on the harness in the dash. once that is hooked up run the rca cables (reds and whites) plug in to amp and then in to back of cd player. once this is all hooked up and fully secure hook the power cable to the battery make good contact and if everything is grounded right you should get the lights on in the amp. Next step hook up the speakers run speaker wire from the amp to your speakers make sure negative goes to negative and positive to positive or you'll get clipping and it will sound like ****. that's pretty much the jist of it. if you have any questions let me know.
    Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Ground wire
    make sure that the wire is grounded to your frame, or any other unpainted metal surface. if no unpainted surface is available, get some sandpaper, and 2 gold, copper, or silver washers (in order from best connection to worst) from your local hardware store. find a bolt near the amp, that wont make something fall apart. take the bolt out, and sand the paint off underneath it. make sure to get all the paint and primer off. put the 2 washers on the bolt, and put the ground wire between the washers. then tighten the bolt nice and tight. this will give you the best possible ground connection, without running the ground to the neg of the battery. if this still doesnt work, try running the ground to the neg of the battery. if that doesnt work, then you should have your amp looked at. hope this helps
    Oct 23, 2008 | Kicker 05C104 Car Subwoofer
    Amp wont power on
    The only effective way to troubleshoot this is with a digital multimeter. Test for voltage on the power terminal and the remote terminal (using the ground terminal for your black probe). If you have voltage on both terminals, check the amp's built-in fuses; if they're good, then you must have a defective amp. If you have voltage on the remote terminal, but none on the power terminal, check your fuse and fuse holder at the front. It's not unusual to have a blown or defective fuse that looks okay.
    Jul 26, 2007 | Profile AP1200 Car Audio Amplifier
    Alpine MRP-M350 Car Audio Amplifier Logo
    181 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
