Question about Maytag LAT3600A Top Load Washer
MY LAT8824AAE machine just fills with water
My LAT8824AAE Maytag machine just fills with water. The timer goes through the cycles but no aggitation or rinsing. It will however work on the shortest of the delicate cycles. I can't find a diagram or information on this. We purchased the home and the previous homeowners left no information on anything. We are just contemplating buying a new one since we can't find a diagram and have no experience in fixing washers. Can you help?
  • zgreat1 Jul 06, 2008
    I have checked the lid switch and the water level (pressure) switch;
    both are in working order. I have "checked" the contacts in the timer
    the best I could and they all seem to have good contacts; however,
    since I could not open this unit to see if the inside contacts are
    good. Since it is a mechanical contact and the timer motor itself
    works, I wonder if I should change the entire timer (unit) at a cost of
    $120.00+.
    Thanks.
    Problem Solver:
  • 11 Answers
If the tmer works on any of the cycles but not on all of them, you might need to purchase a new timer.
Posted on Mar 24, 2007
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag LAT8824AAE rinse and spin but won't agitate
Did you check to see if you had power coming to the motor during agitate cycle? Use the wiring schematic to check 120V or at least a voltage detector. If you do, then the timer is ok and may be the transmission.b663148.jpg
http://tclaundryrepair.com/home
Jul 06, 2008 | Maytag LAT3600A Top Load Washer
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Maytag LAT9235AAE fills with water....
Pt, as long as you verified the lid switch is good, do this simple test. Get a piece of hose the same size as the one going to the pressure switch, connect it and blow into it. See if it starts agitating. If it does, there's your problem..Catriver post back.
Sep 27, 2006 | Maytag 22 Cycles Topload washer, SAV365Z
Maytag LAT3600A Top Load Washer Logo
213 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
