Question about Dryers
Kemore dryer modle 11072622101
I have kenmore gas dryer modle 11072622101. dryer runs but no heat i have replaced the ingitor still not heat
  • Anonymous Mar 31, 2014
    everything turns and blows, but suddenlt no heat
  • 113 Answers
There is a white thermal fuse on the blower assy. It has 2 wires going into it. You can , off course unplug the dryer first, take the 2 wires and attatch them together. Your just bypassing the fuse. Bypass it and try running it. If it works replace the fuse. If not, let me know. Hope that helps , dave www.washermd.com
Posted on Dec 17, 2008
Kemore 80 series gas dryer runs but no heat. I have seen 3 differnt solutions, how do I know which one to do? The gas valve solenoid, the thermal fuse or the ignitor????
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Kenmore 72802 Gas Dryer
After first few cycles on Kenmore 11072622101, burner stops coming on, but ignitor still glows
Your dryer is short-cycling. There are 2 coil valves on the top of the gas valve that need to be replaced. They are black in color, round and about an inch tall with an electrical connection on each one.
Dec 09, 2010 | Kenmore 62622 Electric Dryer
I replaced the ingitor sensor on my Kenmore gas dryer and it still does not heat up. What should I check next.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Kenmore Dryers
Dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 23, 2010 | Kenmore 72972 Gas Dryer
I replced ingnitor in my kemore gas dryer but not flame
Hello Friend, If the igniter is glowing continally and not clicking off, then your therm-disc is definately bad. It's attached to the burner shroud right across from the igniter. It reads the heat off the igniter through a little rectangular hole in the shroud. Replace and problem should be solved.
If igniter is glowing and then cools down and then begins to glow again in a repeating manner then I would say that the thermo-disc is good and you need to replace the gas valve coils. coils are easy to change, they are located on top of gas valve, two screws hold them in place. An easy fix.
Happy to help, Tim.
Jun 30, 2009 | Kenmore 75944 Gas Dryer
My kemore dryer model 11071812001 not drying clothes
Sounds like the problem is the solenoid coils on your gas valve. easy to replace and inexpensive + common. their are 2 coils on the valve that have 2 wires each going to them. Let me know if you have any other questions,
Phil
Jun 10, 2009 | Kenmore 73952 Gas Dryer
Need to replace the heat element for my Dryer Kemore
sorry couldnt find your modle number, but kenmore dryers are enerally whirlpools in which case are easy to replace. the harder issue is determining if this is your problem.I would assume your guessing on a bad heater, only for the face that if you truly did check hte heater, you would find how to remove it( a few screws will release it from its mounting. A simple check with a Meter will determine if indeed it has gone bad. A more likely source or just as common cause of no heat would be a blown thermal fuse, or a bad high limit thermostat, all can be checked for continuity with a meter
Jan 20, 2009 | Kenmore Dryers
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Dryers Logo
264 people viewed this question
Top Dryers Experts
Marvin
Marvin
