Question about Ovens
I need to change a cooker lightbulb
I have a Diplomat Select 910 Double electric Integral oven. It looks like I could open the bulb cover from the inside of the oven but I do not want to force it and break the cover.
The cover is on the left hand side of the inside of the bottom oven.
Can you help
  • sheridan_and Dec 17, 2008
    Sorted! Thank you so much. I did not want to force it off in case I broke it. I now have light in my oven after waiting for my husband to fix it for about 4 months!!! Merry Christmas
  • Anonymous Apr 11, 2009
    Hi there, I have the same problem! Where did you get the replacement bulb from?
  • 8,197 Answers
You should just be able to pull the cover off tords you if it is flush to the serface or you might have to unscrew it. Try thouse things first.
Posted on Dec 17, 2008
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
How do you change the oven lightbulb?
Most require 2 screws to be removed to lift the glass cover from over the bulb. Then simply unscrew the bulb and insert new bulb. A 1/4" nut driver is the best tool for the job.
Sep 08, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Diplomat 910-need instruction/fitting manual
Eventually I have tracked down the manual on ebay-it is available through the seller ' usbdesarch' who appeared to have a selection of manauls available.  If I can post a copy on here when I recieve it I will though I'm not sure how to upload a PDF? Any ideas how I would make this available to the widest audience? I have no website to host the file from.
Jun 02, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Replacement bulb
there are more than one type of bulb for these ovens, the most important thing is that you get one that is rated to withstand temperature of 300oC, or they will shatter with the heat.
Plz rate my solution.
Thanks.
Dec 08, 2008 | Neff U1421 Double circotherm Electric Oven
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to sharemonger@tiscali.co.uk and I will reply with a copy in .pdf file format.
Dec 24, 2007 | Ovens
Light Bulb
open the cover ,unscrew , replace the bulb return cover ,then ok
Dec 23, 2007 | Whirlpool GSC308PR Electric Double Oven
Ovens Logo
297 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
