Question about Panasonic PT-43LC14 43" Rear Projection HDTV
TV turns off after being on for just
I recently replaced the lamp on my PT-43LC14 and thanks to reading posts from others on this site, I was able to reset the timer. However, now I am faced with another problem. The TV automatically shuts off after being on for only about 3-4 minutes. Any thoughts?
I have the same problem and I believe the new problem is the cooling fan is not working properly and the unit is shutting down to protect itself from the heat.
Posted on Dec 25, 2008
Panasonic PT-43LC14; I changed the lamp. I still get the lamp meter warning on the screen when I turn on the TV. How do I reset the lamp meter?
terayamam001,
Here is the procedure,
1. Turn on the television
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or " PIP" button on the remote.
This should solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Resetting the lamp timer for my Panasonic
You need the original remote to reset the lamp. Try to find a neighbor with a similar tv or buy one off ebay.
Mar 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How do i reset lamp hour meter
Turn On tv.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
This will reset lamp timer in Panasonic PT-43LC14
When the lamp time reset procedure is complete, the Lamp Time is Reset screen will appear.
Thanks.
Feb 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Pt-43lc14
To reset the Lamp timer back to zero
simultaneously press the "down split channel" button on the bottom of the remote and the down volume on the TV for 5 seconds or more. You will get a message on the screen that the time has been reset to zero.
May 22, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Tv won't turn on
I did a 2nd replacement with an original Panasonic TY-LA1000 Lamp, now my TV works just llike new.
Dec 17, 2008 | Panasonic PT-43LC14 43" Rear Projection...
TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
Dec 11, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Horizontal grey lines accross screen on Panasonic LCD PT-43LC14
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 08, 2017 | Panasonic PT-43LC14 43" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
268 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
