Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
Posted on Dec 16, 2008
Unit "froze" Is there a reset?
The Television is still on but the remote has lost all function. No button or screen function works.
  • 123gibson Jan 02, 2009
    I have the same problem. solution?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
255
Points
5
I had a similar problem with a MX-3000 2 years ago. The unit would continually freeze. I think it was a problem with the first few units. Since then I've bought a new one and had no problems. Then this weekend, it froze for the first time (the battery is not holding a charge so I think that led to the problem).
If you open the back cover, there is a silver button just above where the battery plugs into the remote. Pushing that button should perform a reset. As an alternative, you can remove the battery at the connector. It is recommended that you use the button and not the connector. It is in there tight on my unit and pulling on the wires can cause a break.
Gary
http://twitter.com/GaryHuff
For HL-T5087SA DLP I have lost all inputs to tv. Can't turn off or on with main control in center. All remote functions do not function.
is there a reset button on the tv? on some electronice devices, if you hold down the power button for about 15 seconds, the unit will reset.
1helpful
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
1helpful
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
Olevia Power button does not work
All functions for Universal URC-R6 For my Olevia quit working. Lost manual for remote, need code to reset
2helpful
3answers
Lost Remote
go here: http://www.partlinx.com/haier.asp
andsearch for the part. You have to start with your state, and then gofrom there. For my area, the remote is 19.99, plus shipping and tax.Also, try eBay. You can find a lot of things there!
10helpful
3answers
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Thomson 32ws83kp
try unpluging the set for 5 minutes the replug in the set you should have function back. if the tv remote is a multi divice remote be sure to hit the TV button first.
2answers
Mx-3000 just froze up
This happened to me today. I plugged the programming cable into the MX 3000 and the screen became "un-froze."
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
