Question about Sony Televison & Video
Sony DVP-NS425P accepts discs but will not play them; C:13:70
The DVD player accepts any disc inserted and shows the play symbol in the display but there is no picture or audio. If I leave a disc in long enough, the following code appears on both the display and the TV screen: C:13:70 and states that the disc is dirty. We cleaned the discs; they work in our laptops.
Again, model #DVP-NS245P. I do not have the serial number with me at this time.
I am also looking for the Sony repair shop closest to 92317.
Joel
ctf1800
  • 4402 Answers
SOURCE: a sony dvp s360
your problem is a common one, it is not your changing the setting that has caused your player to fail. c 1300 failure is quite common and is caused by a weak pickup assy. after changing your setting it has just turned up the power and caused the already weak pickup to fail.
a new picjup assy cost about 55 dollars and laboe is about 50 dollars to install it ..Not really cost efective to repair...todays DVD players do so much more than the 360. so i would say by a new one. good luck
please mark the post with a fixya!
Posted on Feb 07, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
SOURCE: dvd dvp-ns425p picture no sound
Comcast installed the wrong cables ie. red,green,blue vs. yellow white red.
Thanks for your timely response,
Catherine
Posted on Dec 16, 2008
  • 114 Answers
SOURCE: Have a Sony DVD multi disc player model
try different discs, sounds like it doesn't like the media.
Posted on Aug 01, 2009
SOURCE: Sony DVD player DVP-S336 When I play a disc only
Found solution on Sony website eventually!!
Posted on Jan 17, 2010
Why does my sony DVP display "No Disc" for every disc; when they play fine in any other player?
Sony tend to have a notorious disc lasers... couple of things you might want to try..
1. clean the lens using a standard Lens cleaning CD.
2. Try playing a CD (music) instead of DVD (if this works...it is likely that the lens is not reading DVD)
N
Jun 02, 2014 | Sony Dvp-C660 Component Dvd Players
I have a Sony DVP s57p DVD player and my DVD's will not play. Well it does for about a minute then stops and goes back to the menu. How can I fix it? Thank you.
Hello
When you insert disc in it, do it show "reading" display on its display?. If so how much time will it take [in seconds] to return to 'Menu" display?. Check this test for atleast three times, and get the result to me by Fixya. OK.
Mar 11, 2011 | Sony DVP-NS57P
SONY DVP FX-930 unit 8 months old, tried DVD's, CD's insert disc and no matter what disc I install the unit displays "NO DISC".
Your pick up or lenz needs cleaning then your dvd player will be able to read your DVD. Please buy a good DVD cleaner.
Aug 13, 2010 | Sony DVP-FX930 Portable DVD Player
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Lost the remote
If it is Sony DVD Player DVP-NS425P then you need original remote to use above options.
Remote part number is as follows...
clear_spacer.gif " 147772411 " RMT-D153A REMOTE CONTROLand price is approx $18 and available at Sony Accessories. Please write model number of your dvd player DVP-NS425P in search box and see result.
Oct 04, 2008 | Sony DVP-NS425P DVD Player
Sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Aug 14, 2007 | Sony DVP-NS425P DVD Player
Televison & Video Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
