Question about Sharp 27H-S60 TV
Sound problems The picture on this tv is great BUT when programming comes through, the sound is only a buzzing noise (which gets louder as you increase volume) and there is no programming sound (people talking, etc...). Is this a cheap fix for this 10 year old tv or should we simply run the programming through a receiver and speakers? Our programming comes through DirecTV. Thanks a bunch!!!
  • 1 more comment
  • Lori ODay
    Lori ODay Mar 23, 2007
    Are "powered speakers" different from speakers I would hook up to a stereo receiver? I have a set of JBL speakers model j2050. I also have some ALTEC LANSING speakers I'm running with my computer... perhaps those are powered speakers?
  • Lori ODay
    These are my computer speakers...
  • Lori ODay
    Thanks so much!
    President:
  • 3,130 Answers
Make sure it is not a problem with the DTV reciever first by connecting up another smaller TV set to that reciver. if it is the TV set for sure, a cheap fix would be to run the audio outputs of the DTV reciever to a small stereo or a powered speaker. Good Luck
Posted on Mar 23, 2007
  • Larry  Dillon
    Larry Dillon Mar 23, 2007
    Powered speakers are speakers that you plug in to get power to them and have a volume control on them, they have a built in amplifier. Please do not forget to rate this thread. :>)
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Mar 19, 2011 | Teac MC-DX20B CD Shelf System
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
My tv has a lot of red color in the picture
Tt might be the problem with he color circuit board, bring it to the repair shop for repair, or if you can do it do re-soldering to any visual crack at the soldered lead terminal of the components on the circuit board and then try put on to check if the problem goes away?
Nov 10, 2008 | Akai PT5492S 54" Rear Projection...
Loud noise
What is your tv model?
This is an audio problem. capacitors have to check and resistors who change value as the TV works!!!
Sep 24, 2008 | Sanyo DS27820 27" TV
19 in blue screen only sound works great
blue screen is the noise mute screen. however the audio is not getting muted and hence the buzzing....meaning the tuner on the TV is not getting locked on to the station/frequency
1. check your antenna if you are using one. Autotune
OR
2. Reconnect coax from the cable box to Tv and autotune.
OR
3.Use the Video out from the cable box and connect it to one of the video inputs on the TV. Switch your Tv to that component. Use the cable box to change channels (Best case scenerio)
Feb 28, 2008 | Westinghouse SK-26H240S Television
PS32500 32" TV Problem
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Feb 19, 2008 | Proscan PS32500 32" TV
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Buzzing coming from speakers
The "IF coil" is used for all channels, so if channel 5 is clear but 25 is not, the problem is not in the IF. If your IF coil was loose or bad, all channels would drift off and you would have no picture or sound. If you have the TV set to "SAP", some channels would have no sound at all, so I doubt that your settings are wrong. I suspect that the problem is with your cable signal, not your TV.
Sep 01, 2007 | Televison & Video
SanyoDS25390 Tv good picture buzzing noise
What are you using as a source? If its a cable/satallite box, double check that first. If its a video input or a scart input, swap out the cables. If it still there you could have an input problem or a filter capacitor going bad. Does the hum get louder with sound? If it does it is an input source and or cables. Good luck Ps please dont forget to rate this thread.
Nov 25, 2006 | Sanyo DS25390 TV
Televison & Video Logo
118 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
