SOURCE: microwave oven does not warm food up
I have not solved my problem,I have decided to buy a new microwave rather than pay for this amount of money on a telephone advice when you have said on your site that it is free.I will also spend further amount of money, to call an electrician after your advice,so I will be better of buying a new one.
SOURCE: GE spacemaker microwave stopped heating
I have a GE Over the oven microwave Model JVM1660BB. When heating it had started making a low humming noise. I could open the door and then close it, and the noise stopped. Now the oven won't heat at all. the light comes and the fan works. Jimbo
SOURCE: lg wavedom microwave food not
I have a problem with my LG microwave wavedom .it makes a loud noize and i does light up and turns around but its not heating any of the food which i put in to warm. Can anyone can help please? What can i do?
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
SOURCE: My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
