Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a d52w23 rca less than three years old
I have only used the set for about half of the time ive had it..when i turn on the set the power light comes on, then i hear a sizzle, smell some burning and an arc occurs on the back right hand side of the set, angle is while facing the screen. over the phone repairman says it may be the "transformer". rca's parts list does not list a "transformer". what is this and could this be the problem?
    Genius:
  • 1,030 Answers
Sounds like what is know as the flyback. also known as the ihvt and yes this is a transformer. to get the correct part for rca you have to get the model extension number this will be like d52w23yx1 or yx2 or something like that. generally when we replace the flyback. we check the horizontal output because it is most likely shorted
Posted on Dec 17, 2008
Replace a projection bulb on a RCA D52W23?
I have this tv.
pull it out and start undoing the screws towards the bottom half of the tv around the back, get the speaker grille off and then in there is your access cover for your bulbs. theres three of them red blue green. the bulb assemblies and circuit boards are integrated 3 bulbs -three separate assemblies. you will probably have to turn the tv back on when its disassembled to see which bulb went.
jm
Nov 12, 2010 | RCA D52W23 52" HDTV CRT TV
We have a RCA D52w23 rear projection tv that powers off.
most likley the deflection board is at issue. Thats the number one board which fails in that chassis.
Mar 15, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA D52W23 won't turn on
The set is in shut down mode due to a fault detected in power supply/vertical or horizontal deflection circuits.
The common problems with this model that will cause the symptom you describe are bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders especially under flyback area.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned, otherwise it's best to seek a qualified RCA tech for an estimate/service call.
Reply to this post if you need more advice.
Dec 08, 2009 | RCA D52W23 52" HDTV CRT TV
My RCA d52w23 will not turn on. upon turning power on (either by front button or remote) the green light comes on 3 times and makes a mousey squeek. please help!!!!
there can be a few things that can cause this problem
take the back off and on the board on the left side look at the caps there ae 4 of interest three are radial pc mount and stand up the tops may look puffed up those will need to be replaced
locations i think are c140 c120 c114
the check solder ar the .082 200 box cap in the base circuit of the horizontal output transistor
that will most likely take care of your problem
Nov 09, 2009 | RCA D52W23 52" HDTV CRT TV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Just moved tv and now will not power on. i do hear click noise in speaker ,
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Jan 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on RCA LCD TV
Oct 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
