Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My liftmaster moter hum's and the chain drive will not move
The door arreared to be frozen to the ground before opening. It broke free and opened, but now will not respond to the opener. It only hum's for about five second's.
  • nlsharks Jan 08, 2009
    door appeared a little frozen when opened, broke free and now motor hums but chain drive will not engage. Cannot figure out what is wrong.
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    Try unplugging it @ 2 mins. and plugging back in. If that does not work, what kind of operator do you have?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Try opening the case and looking to see if there is a white plasic powder in the bottom of the case. if there is you will have to replace the gears #41C4220A.
Posted on Jan 11, 2009
M otor hums but door does not open
If the motor is running and the chain or belt isn't moving, you have a broken gear in the opener.
Mar 26, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Crafstman Garage door wireless opener. Model 139.53615SR . The door hums but nothing happens. The chain doesn't move. The springs on the door broke last year and i replaced both of them....
My plastic gear stripped soon after a spring broke. I think the broken spring put a huge load on the opener that day and ruined the gear. Replacement wasn't too hard. It will be obvious when you remove the cover if the gear is stripped. Here are instructions:
http://tinyurl.com/gearfix
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door does not open or close
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain powerdrive door opener will not move. moter hums but chain will not move
CHECK TO SEE IF HE TRAVELER IS AGAINST THE BOLT ON THE RAIL. IF IT IS YOU WILL NEED TO LOOSEN THE CHAIN / BELT TO GET IT TO MOVE THEN ADJUST THE TRAVEL LIMIT SO IT GOES UP / DOWN LESS AND DOESN'T HIT THE BOLT.
HOPE THIS HELPS
Jan 10, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Liftmaster door opener, motor hums but chain and door does not move. Any ideas? Thanks
If the motor is running but the chain isn't moving you have a stripped drive gear. Remove the cover from the motor unit and check. It should be obvious.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Craftsman 1/2 horse garage door opener. When I push the button, I can hear it hum, but the chain won't move and it seems the sprocket is frozen?
If your door is stuck in the open position you will find the trolley is jammed against a bolt just in front of the motor unit. Remove that bolt and run the opener until the door closes. Now locate the 'up limit' control on the side of the motor unit and turn it 2 times in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster - motor hums, doesn't turn. Removed
My neighbor guy, who knows a lot about stuff, told me to get a new one.
Good solution.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
819 people viewed this question
Top liftmaster Electrical Supplies Experts
cavs1
Gil Shultz
Mike
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
