Question about Kenmore 75944 Gas Dryer
Dryer not gettig hot replaced ingitor no help
Dryer not getting hot
  • 8,197 Answers
You need to call a repair man to replace to magnetic coiles. That is what gets it to heet.
Posted on Dec 16, 2008
Dryer not gettig hot.
Must be a gas model. They typically do that when the gas solenoids get age on them. They work once then quit, then work some more when cooled back down after a long period of time. Very hard to diagnose for the DIY person but pretty much a common probo associated gas dryers. Swap out the solenoids and party on!
If your is an electric model I would check the vent pipe or filter chute for parcial blocking which might cause safety themostats to shut down the heat.
Jun 16, 2012 | Whirlpool Dryers
My gas dryer does not warm up and becasue of that clothes do not dry. Mod: 110 70722990
doesnt warm most likely to one of four parts being at fault the hi limit thermistor the low limit or safety thermistor some units also have a start relay or the heater all these pieces can be checked for faults by doing continuity tests on them using a multimeter this link is also the entire parts diagram for your machine should show you how to take it apart and which pieces im refering to for you to test ooook skip half of doing that thought you had an electric instead you would first test the ignitor should be drawing between 3-3.3 amps if this is any less then replace it less would constitute a weak ingitor and would be why the gas is not lighting following this you would test the coils to assure that you are getting voltage to the coils if you click this link here it will show your burner assembly part number 4 is the ingitor 13, 14 would be the two coils that i had mentioned earlier if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
heres your link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11070722990/0582/0151200/10052613/00001?blt=06&prst=0&shdMod=11070722990
Apr 08, 2011 | Kenmore Dryers
Where is the igniter for kenmore 80 series gas dryer
it is located down the bottom of the machine here is a video on how to replace the ignitor in your machine note this may note be the exact ingitor but this s the basic way it is done http://www.youtube.com/watch?v=O3ehA9DzQsE if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Dryers
I have a atlantis gas dryer that doesn't blow hot air anymore.
The Gas burning control didn't turn on. Common problem is a thermal sensor problem. You can see the ingitor turns on then turns off without burning. The thermal sensor will sense the heat from the ignitor to turn on the gas valve. If it doesn't sense the heat gas won't be turn on. If gas is not on the ignitor will turn off after a pre set time interval. Need to take off the panel cover to see what have been discussed here. Good Luck.
Sep 21, 2010 | Maytag Dryers
Does this dryer have a piloit light that has to be lit?
no it should light on its own by the ignitor if the ignitor is not lighting the unit then check with an amp meter on the ingitor wire shoudl be drawing 3.3 amps any less then replace
Jul 18, 2010 | Dryers
Kemore dryer modle 11072622101
There is a white thermal fuse on the blower assy. It has 2 wires going into it. You can , off course unplug the dryer first, take the 2 wires and attatch them together. Your just bypassing the fuse. Bypass it and try running it. If it works replace the fuse. If not, let me know. Hope that helps , dave www.washermd.com
Dec 16, 2008 | Dryers
How do I check to see if the ignitor glow red?
you can remove the front replace the door and check the ingitor .. let me know and I can guide you step by step
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer.
check ingitor see it it glows red hot then check flames sensor and or gas solenoids
Aug 20, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 75944 Gas Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
