Water pump need to order water pump
  • 113 Answers
Ok. What model do you have. I can get you the part #, or the part itself.
Posted on Dec 17, 2008
How do l remove my water pump
I'd imagine you would remove whatever in order to get at the water pump, then remove the water pump mounting bolts, remove water pump. Installation is the reverse of removal.
If you want more info, I need year--make--model? My database will only cover vehicles sold in the US.
Oct 31, 2016 | Cars & Trucks
Water pump pulley it is pressed on to the pump how to remove the fan clutch and fan to this water pump
Not enough information to answer. Need manufacturer, year, model, and engine size in order to answer the question.
Oct 17, 2015 | Cars & Trucks
Water Pump??
You need to find out exactly where it is coming from in order to figure out what needs repairing. Choices are usually either a hose in the cooling system or a gasket on the intact manifold.
Feb 08, 2018 | 1996 Pontiac Bonneville SE CA Value
Replace water pump
Well the bad news is if you have the 3.5 liter engine, the entire engine assembly needs to be removed in order to change the water pump. If you happen to have the 3.3 liter engine you will need to remove the timing belt in order to get at it. Need to know what your engine size is before I can help any further
Oct 11, 2013 | 2008 Toyota Highlander
Replace water pump
Instructions
  1. Take Out the Old Pump
    • . Jack up the GMC truck using the jack stands to stabilize the vehicle. Disconnect the negative battery cable by opening the hood and using a screwdriver to unscrew the clamp that connects the negative battery cable to the battery post.
    • 2Unscrew the radiator cap to release the pressure. Locate the drain plug underneath the radiator, on the right side. Remove it. Catch the coolant in a clean container and immediately clean up any spills.
      • 3
    • Disconnect the parts leading to the water pump on the engine using an adjustable wrench. In the following order, this includes: air outlet ducts, radiator hose (both ends), coolant fan and clutch, drive belt, surge tank hose and heater hose. As you remove each part, lay it out, alongside its bolts, in the order disconnected.
    • 4Remove the water pump using an adjustable wrench to unbolt the water pump from the block. Take the bolts out in any order. If needed, chisel in the seam between the water pump and the block to separate the two parts.
    • 5Remove the gasket, which may be in pieces on both the water pump and the engine. Wipe the pieces away with a clean shop rag if possible or scrape them away with the chisel if needed.
    Put in a New Pump
    • 6Fit the new gasket onto the new GMC 5.7 water pump. Hold the gasket in place as you mount both pieces onto the engine, where the old water pump sat.
    • 7Set the new bolts carefully into the holes in any order. Many 5.7 engines use two rounds of tightening, first with 11 foot pounds of torque and then with 22 foot pounds of torque. Reconnect the rest of the parts in the order you took them off, replacing any worn or damaged parts along the way.
    • 8Place the drain plug back in the bottom of the radiator. Refill it with coolant as specified in your owner's manual. Screw the radiator cap back on. Then, lower the truck back to the ground, close the hood and clean up any spilled coolant.
    • 9Replace and tighten the negative battery cable to the post with the screwdriver. Start the GMC engine and check for leaks. Don't forget to remove the cinder blocks before driving.
Oct 23, 2012 | 1997 GMC Savana
Pump,run,but,no,water,no,susion
May be that you need to prime the pump...this is accomplished by filling the pump housing with water and then reconnecting to system...you may need to do this several times in order to get it running
Apr 26, 2011 | Plumbing
My1990 ford f-250 leaks coolant below fan when i put it in.how do i fix it?
Hi:) Sounds like the water pump needs to be replaced. you need to remove the coolant,belt,fan,water pump bolts and you need a new gasket and water pump and replace in opposite order.
Mar 17, 2011 | 1990 Ford F250
Waterpump leak
Hello bladresha: My name is Roger and I will help you. The water pump on the 4.0 engine is located at the rear of the motor inside of the water cross over tube. It does require special tools in order to remove and install. This pump does not bolt in or on to the motor. This is a twist and lock in pump. Just like the Cadillac Northstar motor. You will need to remove the upper hose housing from the crossover tube. Look inside of the housing and you will see the water pump. You will need to use the special tool in order to unlock the water pump. Pay close attention to the water pump when removed. There will be a notch in one of the ears. This is a location notch. The new pump must go in the same notch. I have attached a picture that shows the water pump location. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Rogerrogerf1_27.jpgrogerf1_28.jpg
Feb 09, 2011 | 1998 Oldsmobile Aurora
Need to replace water pump. how easy it it?
Pretty easy. Just drain antifreeze. Then loosen 4 bolts that holds fan to pulley. Remove plastic fan schroud and fan pulley. Loosen water pump bolts in criss cross pattern and remove water pump. Clean surface install new gasket and water pump install in reverse order. Tighten in staggerd order to keep from breaking and warping. Don't forget to change thermostat good time to replace. Part should be about 50 bucs at your local parts store.
May 02, 2010 | 1999 GMC Yukon
Is it necessary to remove the thermostat housing in order to replace a water pump bypass hose? Mechanic advises that my 2000 Mountaineer's small by-pass hose is leaking. In order to replace it, either the...
in the upper radiator hose to the engine side of an elbow with 2 screws in there is the thermostat and water pump need to remove the fan belt clucht with the fan off the bottom hose that goes from the radiator to the pump to remove the screws remove the pump the pump clean the surface and install the new pump
Aug 07, 2009 | 2000 Mercury Mountaineer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
