Question about Brother HL-4040CN Laser Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
I was wondering what's the difference between Brother HL-4040CN and HL-4050CDN printers beside the fact that HL-4050CDN takes care of printing both sides of the paper? Do the two of them have the same color printing quality?
Thank you
  • Anonymous Feb 06, 2009
    recherche logiciel
  • 4 Answers
HL-4040CDN supports BR--Script (like Postscript) and
HL-4040CN does not.
So, there is a "postscript" diver for the 4040CDN, but not for the 4040CN.
Posted on Nov 11, 2009
The D stands for duplex printing (both sides of paper)
Posted on Dec 16, 2008
Brother 4040CN
This message will appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one
May 21, 2010 | Brother HL-4040CN Laser Printer
How do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Mar 25, 2010 | Brother HL-4040CN Laser Printer
My hl 4040cn says drum ends soon. do I have to
Yes, The drum units have a set number of copies before they need to be replaced. This printer has a drum life of 17000 pages. The part number for the drum is DR110CL Just do a Google search or check your local office supply store.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | Brother HL-4040CN Laser Printer
Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Sep 16, 2009 | Brother HL-4040CN Laser Printer
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Sep 08, 2009 | Brother HL-4040CN Laser Printer
Are those papers printable on Brother HL-4050CDN ?
Hello !
If you want to print on canvas you need to use a plotter which use ink. An example is Roland or Epson. Personal i use Epson T5200 plotter and the result is awesome.
Apr 16, 2017 | Brother HL-4050CDN Printer
Drum error : slide the green tab on drum unit in each colour?
you forgot to slide the tab, unless you do this you cannot use your printer im afraid, drum unit is a cylindrical part unit, unless otherewise you correct this instlltion procedure there is no othere way around it
cheers
Nov 25, 2008 | Brother HL-4050CDN Printer
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
Brother HL-4040CN Laser Printer Logo
916 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
