Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Samsung projection tv
My 62 inch (?) tv powers up.sometimes the lamp will light for about 15 seconds then shut off. more often the lamp wont light. in both instances the "lamp"indicator light on the front blinks. if the lamp lights then shuts off,then all three indicators blink,"timer","lamp",and "temp".
the lamp amp board has a 350vdc input. im waiting for the rear cover ,lost in transit,so im not positive on the model.
  • teebonz Dec 17, 2008
    model # hln617w
    Champion:
  • 240 Answers
Change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Posted on Jan 11, 2009
Hln4365w samsung tv
DLPs have had terrible reputation for faulty power supplies. Does the power light flash when it shuts down? How many hours are on the lamp?
Nov 08, 2013 | Samsung Hln4365w 43-inch Widescreen...
Light indicater keeps coming on light wont stop. mitsubisi brand
Have you had the bulb replaced in the unit yet? There is a timer in the unit that is set to a specific number of hours. If that is not reset when the lamp is changed you may still have this problem. The issue could also be unrelated to the lamp but in the power supply itself. I think you would be best advised to contact a repair shop about the unit.
May 12, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I have a 62 inch samsung lcd tv and it keeps turning off. The sleeper mode is not on. I thought it was the power strip and i plugged it into the wall and it still did it about every 15 to 30 minutes
Your TV is DLP If all fans are running then its your Lamp BP96-00826A and if Lamp is Good then it will be Lamp Ballast BP47-00021A Lamps only Last for 5,000 hrs some Last up to 8,000hrs
Call FOX 1-800-227-5369 Lamp $109.00
Dec 21, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung hlr5067w shuts of after 30 seconds... flashes red
I would suspect the lamp first as they can cause intermittent shut down issues.
Nov 03, 2009 | Samsung HLR5064W DLP Projection TV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
HL-p4663w/3 flashing lights
The Problem you have with your set is that your lamp is dead. you will need replace it. The Part number for the lamp is on the side of the TV. BP96-00826A is the part number. You will need a service Person to change the Hour timer in the service Menu.
Jan 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
215 people viewed this question
Jerry Greenberg
Jerry Greenberg
