Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx condenser dryer not heating and turns itself off.
My Bosch Classixx condenser dryer does not get warm. It stops after a few minutes and emits three sets of three beeps. Both the 'Drying' and 'Anti-Crease/End' lights flash.
  • Anonymous Dec 18, 2008
    Our dryer also does not heat, any help?
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Hi Bosch classixx condenser dryer
Welcome to FixYa,
Based on your post it may just be the hi-limit has tripped. Here's what I'd do/check.
**Unplug the unit from the wall or switch off the breaker...safety first**
Once the dryer has been disconnected from any power, remove the rear panel...
i.e.
Once the panel has successfully been removed, you'll see the heater with the Hi-Limit and NTC attached. The Hi-limit is the thermostat with the red button in the center...
i.e.
push it in to reset it. As you can see by the images I've provided, if you have a multi-meter or ohm meter you can verify the proper values of the listed components.
If the hi-limit is tripped, obviously something triggered it, you can check the possible culprits such as the NTC's or heater with the info I provided above as I alluded to.
( Even so, I'd suggest running it through a cycle or two with clothes and monitor it's performance, it may have tripped simply due to poor air flow from a large load etc. and therefore nothing is actually wrong...human error )
You may run the dryer momentarily without the rear panel in place ( provided nothing electrical has been disconnected, don't attempt an entire cycle. ) just to witness the heater functioning, but it isn't recommended for much longer than a minute or two.
Thank you for choosing FixYa and please let me know what you find out or if you indeed require further assistance.
Good luck.
Regards,
Macmarkus :)
Posted on Dec 01, 2010
  • 414 Answers
SOURCE: manual for WTE84105GB
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Posted on Jul 08, 2010
HAVE A BOSCH CLASSIXX CONDENSER DRYER KEEPS SWITCHING OFF AFTER A FEW MINUTES
Have you tried cleaning out the metal concertina-like element inside the bottom trap door? This clogged up caused mine to stop & also to drip some water on floor
Apr 17, 2017 | Bosch Washing Machines
Why my bosch classixx keeps stopping every 5 minutes
The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 13, 2014 | Bosch Classixx WVF 2402 Front Load...
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Hi I have got problems with my Bosch Classixx electric dryer It runs for a few minutes and then it stops I have cleaned the filter system etc and looks as clean as a whistle It seems to stop as it...
Clean the front under the lint filter has a sensor on the left near the lint pin. purchase a special long thin cleaner for vac from: All rand Vacuums 561-967-3575 GREAT
Sep 08, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Dec 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
The tumble dryer does not dry The heater element warms up The fan motor is turning but no heat gets into the drum. Bosch Classixx wash and dry
does the element heat up then turn right back off after a few seconds? if so, there is 2 sensors that control the heat element, one is in the duct right after the fan. when this sensor senses too hot, it will shut down the heat element. either your sensor is bad, or the lint is not getting out, causing the heat to build up in the duct.
Oct 27, 2008 | Bosch Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
277 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
