Question about Kenmore 24032\24036 Top Load Washer
Accessing coupler on kenmore 70: problem pulling water pump off
Concerned about how much pulling without damaging pump or shaft
can see shredded coupler
  • Kenmore Master
  • 5,568 Answers
Those couplings do corrode and make removal tough. If you have some penetrating lube like WD-40, soaking them overnight can often help. Don't use a lubricant that is meant to actually lubricate things; if you get some on pullies, it can create new problems. WD-40 (and 'penetrating' competitors) evaporate fairly quickly.
Posted on Dec 16, 2008
My kenmore washer don't spin
Probably need more information but guessing its a top loader and the motor is turning but the drum is not spinning but the water is being emptied? If that is the case it is probably a worn out coupling that needs replaced. The pump shaft runs through the gear of the pump body and also through a coupler. The coupler will eventually wear to the point the motor shaft just spins inside the coupler. If it is a front loader there is probably a V belt that is broken or damaged.
Oct 05, 2015 | Kenmore Washing Machines
I HAVE A KENMORE SERIES 70 WASHING MACHINE. IT FILLS UP WITH WATER BUT WHEN IT GOES INTO WASH CYCLE, IT DOESN'T AGITATE, IT JUST MAKES A LOUD NOISE. IT WILL DRAIN WATER BUT DOESN'T SPIN. IT ONLY MAKES LOUD...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Jan 13, 2011 | Kenmore Washing Machines
Kenmore Model 110.20702990 (top loader Series 70). Machine fills with water, cycle timer(s) seem to be working ok, motor seems to be working and the water pumps out after the wash and rinse cycle. ...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702990/0582/0153200?pathTaken=
Jan 05, 2011 | Kenmore Washing Machines
I have model #23732200 70 series top loading washer. While on spin cycle it will not spin full speed to drain water. What it could be with even small load? morris0827@verizon.net
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities: since it will spin. None of the suggestions are very expensive.
spinning.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Dec 09, 2010 | Kenmore Washing Machines
Kenmore 70 series super capacity washer will not spin water out on full loads but works fine on smaller loads.
spinning.
damaged.
Dec 05, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I need an owners manual for troubleshooting for a kenmore 70 series model 110 20722, serial CK4011186, type 111 When it spins out the wash water and rinse water not all of it goes out? Does it have a...
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Based on the 20722 Stock Number, the following might be the Sears diagram site for your washer. Check under the Lid for the exact model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Two possibilities:
These models don't really have a filter but I'd check the hoses to and from the pump and inside the pump to look for any obstructions in addition to the Motor Coupler (about a $20 part) and the clutch.
Jul 01, 2010 | Kenmore Washing Machines
Kenmore series 70 #11026732500 spin problem
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26732500&pathTaken=partSearch
I'm assuming that you mean that the washer won.t spin with a load but will without one.
Two possibilities:
As an aside, the long pole (agitator shaft) shouldn't turn if you hold it when the washer is in spin mode. Basically, the oil "friction" within the gearcase is turning the shaft when in spin mode and if you hold it, it shouldn't turn.
When the washer is in spin mode, the "drive tube" which turns the drum is driven by the clutch.
Also see the following for how these gearcases work and how the agitator shaft is released by the "agitate cams" when in spin mode.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
May 27, 2010 | Kenmore Washing Machines
Model 22748 kenmore 70 series washer. fills but
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92274800&pathTaken=partSearch
It is also likely the source of the burning smell.
(Sears price $18.86 but available from most appliance repair shops)
Apr 22, 2010 | Kenmore Washing Machines
Series 70 Kenmore makes a whirring sound during agitation, spin and rinse cycles. It's louder during the agitation and rinse than the spin cycle. Otherwise it works fine. The lid switch seems to be OK...
MOST LIKELY SOLUTION:
Apr 20, 2010 | Kenmore Washing Machines
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore 24032\24036 Top Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
