Question about Proscan PS60690 60" Rear Projection Television
Main fuse keeps blowing on my Proscan 60690
I have a Proscan 60680, chasis number PTK171ABC C 2404 K1D, that I purchased in 1992. In the last 3 years, I have had to replace the HV splitter twice. Now the main fuse (where electical plug plugs into tv) blows everytime I replace fuse and plug tv back into outlet.
Would greatly appreciate any help with what could be causing this!
Thank you,
Jeff
  • StumpMan Dec 17, 2008
    Thanks, I will check it out.
    Problem Solver:
  • 8 Answers
Check the voltage reg.
Posted on Dec 17, 2008
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Feb 07, 2016 | Water Water Heaters
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
My rca model # p52721lv keeps blowing the fuse have replaced several times with the same results.
the problem with this tv is the main regulator , u can buy this repair kit by the chasis # or by the model # the best store to buy this unit is from union electronics , just look on the back of the unit and see what chasis it is ctc169 , or ctc197 or 95 , 95 and 97 are the same ,
Jul 18, 2011 | RCA P46924 46" Rear Projection Television
1992 Geo Tracker keeps blowing fuse for ignition coi/meter(15 amp)-Checked wiring harness and components and no problems found-Will usually run for 1 to 2 weeks then blow fuse several times-then will run...
could be the main computer - but last time a saw - they where over a $1000.00 dollars. suggest finding some one to install a matching amperage circuit breaker in place of fuse. it will trip and automatically reset - caution : if problem gets worse, could cause wire melting and fire
Oct 27, 2009 | 1992 Geo Tracker
YEAR OF MANUFACTURE OF MY BIKE
your bike should be a 1992. You go by the 10th digit, and you can find VIN charts online to tell you the year of the corresponding letter. Starting in 2001, it switched to numbers. The number in the 10th digit corresponds to the last digit of the year.
Jun 16, 2009 | 2007 kawasaki KLX 250
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Mar 19, 2009 | 1994 Toyota Camry
3 light x-lines across TV screen
From elsewhere on the web:
"Proscan used to be the RCA high-end trademark; RCA (at least the TVs) was purchased by Thomson; they leased the proscan name to a Korean outfit that has the TVs made in China.
I've never owned a Proscan (post RCA)... but the internet buzz is that they are of inferior quality and that it's virtually impossible to get support in the USA. I would qualify that: Costco is selling Proscan TVs; they extend the warranty by one year (to two years); and if you have a problem, ya got Costco behind you. So I guess unless you buy one at Costco, you should pass"
Perhaps you need to contact the entity at which you purchased the television.
Mar 02, 2009 | Proscan 42LA30H 42 in. LCD Television
92 swift
I had this problem in a commodore and it was the old stereo wires shorting on the body
Aug 15, 2008 | 1992 Suzuki Swift
High voltage splitter
I have read on this forum that for the Proscan 60690 Chasis # PTK 188AC, the HV Splitter part # is 205064 and can be easily purchased on eBay for around $20.- $25.
Sep 28, 2007 | Proscan PS60690 60" Rear Projection...
Proscan PS32610
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
Sep 25, 2007 | Proscan PS36810 TV
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
214 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
