Question about NEC Electra Professional ETW-16DC-2
Need to program extension to ring on incoming calls
Nec electra professional level I.
Need to program extension and line to ring onincoming calls.
    Problem Solver:
  • 16 Answers
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Posted on Jan 01, 2009
How do I change the display name on a NEC ETW-16DC-1 display phone that is on an Electra Professional Level II phone system?
You will probably need to add the extension name via system programming. The following installation manual for the NEC Professional Level ll phone system may help (copy & paste)
http://pdf.textfiles.com/manuals/TELECOM-A-E/Electra%20Professional%20Level%20III%20Install%20Manual.pdf
Jun 14, 2018 | NEC Lands Phones
I have 7 incoming lines, I can receive calls on all seven, but I am not able to make outbound calls from any of those lines. I have 6 extensions, out of those six extensions only one is able to make and...
Do you have actual appearance of each line, or just a placement button for calls received, a Call Arrival key, or car key. You can't grab a car key to make a call, the outgoing calls just land on them after you dial 9 or whatever the code is. Anyway, that would have to be changed in system programming, an actual tech would have to look at that. Or the phones are restricted and need a code entered to bypass the restriction. I have no idea how those codes might be set up.
Oct 09, 2013 | NEC Electra Professional ETW-16DC-2
Why does another extension ring at my extension
Someone thought it'd be a good idea for your extension to back up that extension when answsering incoming calls, or their extension is forwarded to yours. Either cancel the call forwarding with the right code (be careful not to remove forwarding to voicemail), or have someone remove the program on your extension which makes you a backup to the other one.
Jul 01, 2010 | NEC Electra Elite DTU 16D-2 Corded Phone
Programming
yes enter program mode and change MB 4-01 for your port number. Assignment of ringing per phone.
Jun 02, 2009 | NEC ETW 16DC-1 Corded Phone
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
How to I forward incoming calls on my phone to a cell phone 3?
Call forward, off-premise is available on the NEC Electra Professional phone system if you have the Level II system (metal cabinet, not plastic) and you have system software level 700 (7.00) or higher. To get your system software level, press <FNC> - 3 from any display telephone when idle. The procedure to forward is (with phone idle): press <FNC> - dial 60, dial trunk access code (usually - 9), dial telephone number, press <FNC>. Additionally, your station class must be set to allow this feature (by default it is not allowed) and you may need trunk-to-trunk capability turned on in system programming (which is also, by default, not allowed). Hope that all helps.
Dec 30, 2008 | NEC Electra Professional ETW-16DC-2
NEC Electra Professional Level I Upgrade
The NEC Electra Professional Level 1 has a maximum CO line capacity of 8 in any configuration. If you need more outside phone lines, you will need a different system. If you need to limit cost as much as possible, the cheapest avenue would be to upgrade to a used Electra Professional Level II. That way you can still use the same telephone instruments, but ALL cabinet hardware would be different. Also, you can only get to 8 outside lines if you have software level 3.00 or higher by using the COI-C(2A)-10 card. To verify which software version you have, I think you press FNC(3) on sta. 10 ( or the first station in the system). If that doesn't work, let me know, and we can access the system program to verify version number.
Dec 29, 2008 | NEC Electra Professional ETW-16DC-2
LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You actually need to set the ringing in program mode. Your NEC vendor should be able to help.
Check out LDTSNJ.com for low price service rates.
May 19, 2008 | NEC Electra Elite 32D-1 Corded Phone
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
NEC Electra Professional ETW-16DC-2 Logo
467 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
