Question about HP Pavilion N5350 Notebook
Bad hard drive on n5350
Do I need to remove the key board to to replace it? if so how?
    Problem Solver:
  • 6 Answers
Most laptops keep the hard drive on the bottom side. There is a cover screwed over the area with usually 2 screws, the cover is identified by the typical 3 disc stacked symbol. In some cases the hard drive slides out of the side, still being held by two screws, some even slide of the front and you must remove 2 rubber stoppers to uncover the screw holes. Each location usually has the hard drive symbol I described eariler. Hope this helps!
Posted on Dec 17, 2008
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
I have just replaced a bad motherboard with the same board in an hp pravilion p6653 desktop which is running an oem windows 7 version. It recognizes the motherboard as new hardware and begins startup...
You should still be able to use the current key. Try adding the key in Control Panel > System. You can even try loading Windows on to itself. Not a clean install. You can even remove the hard drive and use it as a second drive or connect it via USB. gl
Feb 05, 2013 | Computers & Internet
BIOS can not recognize HDD
Mother board hard drive controller may be bad requiring replacement of motherboard. Re format hard drive.I would remove hard rive and install it into my external drive module and connect it to another computer then exercise a hard drive repair program.
Dec 14, 2012 | Toshiba Satellite 1900-102...
I turn the laptop on, just as the desktop appears the screen goes black and I can't do anything.
try removing the battery while the laptop is off of course and then plugging in the power adapter and turning it on. If all works then its your battery that is the culprit and needs to be replaced ....if it still doesn't work you may have bad memory if you know how to remove the memory with the laptop off and the battery removed then do so ...it could be one of them .. but replacing them in-pairs is also a good time to upgrade to more memory for better performance 'if its not the memory and not the battery could be a flaky hard drive or you will need a new motherboard if the hard drive is flaky all may be lost bad mother board means its time for a new computer ...but your files may be OK on the old hard drive and could b saved to your new unit ....good luck !!
Sep 24, 2011 | Toshiba Satellite A135-S4527 Notebook
I need to transport my HP desktop. Do I need to seat my hard drive, and if so how do I do that?
Hi vandrie john...
No you do not need to seat your hard drive...
I would rap it up with bubble rap very good, securely pack it in a good (cardboard) box, and tape the outside of the box with strong shipping tape to make sure it does not have a problem with the shipping.
Please take time to rate me
Aug 12, 2011 | HP Pavilion N5350 Notebook
Black Screen on start-up. Laptop works and LED lights are on. I did a Hard Reset but screen is still black.
Hook up an external monitor to the laptop. See if you get video on it. If you do, then your LCD screen or your Inverter board is bad. If you need instruction on how to replace the screen and where to purchase a new screen, let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 22, 2010 | HP Pavilion N5350 Notebook
N5350 will not power up with power adapter
Are you certain the panel didn't simply give out? Try attaching an external monitor via the rgb/vga connector. If everything id running, then thst is the likely culprit.
Oct 30, 2008 | HP Pavilion N5350 Notebook
Replacement of hard disk in Vaio VGN-A150
Well, it's not good news. Official word from Sony:
Knowledge Article C309925...
Can the notebook hard drive be upgraded or replaced
Hard drive upgrades in the notebook computer are not supported.
NOTES:
* Some notebook computer have instructions for warranty replacement of the hard drive by an end user.
* Although third-party upgrades may be available for some models, they are not supported.
* If the hard drive needs service, repair should be done by an authorized Sony service center.
* External hard drives may be attached if the appropriate connections are available.
This basically means complete disassembly of the laptop is required to get at the hard drive. Not that it can't be done. Just that it'll be a major pain in the .... you know.
There is no hidden key!
Jul 24, 2008 | Sony VAIO VGN-A150 Notebook
Motherboard
You need to contact HP for that board.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 04, 2008 | HP Pavilion N5350 Notebook
HP Pavilion N5350 Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
