Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I purchased a used ge electric oven pt. no. 326B1036P001-0, It has no other numbers on it and the manual seams to be gone. Can you tell me if this is to run on 110 or 220 .and how many amps does it need to run. Also there are 4 wires on it white, black and red.. but why is the white wire connected to the ground wire.
fridgetech
  • 473 Answers
SOURCE: GE Spectra oven
First thing to do is unplug the range for a couple minutes then plug it back in. In some rare cases this will reset the control. If this doesn't work then you will need to use a meter and check to see if you are getting proper voltage to the control (clock) and the light. If you are getting voltage to the clock then it is bad. Let me know what you find and give me the complete model # from the sticker on the range so I can look into this for you better.
Posted on Nov 19, 2007
bbtoast
  • 319 Answers
SOURCE: self cleaning cycle
Between 3 and 5 hours. Most likely 3 hours unless yours has the adjustable setting for cleaning, then you can clean longer.
Posted on Jan 01, 2008
  • 1073 Answers
SOURCE: how to connect a 220 stove with 2 110 cables
cannot be done you would be using the same side of the line and it would be a direct short
Posted on Apr 27, 2008
  • 330 Answers
SOURCE: Ge spacemaker cooking center wiring diagram
1. usually green wire is ground, connct to the body for your
stove.
2. the white neutal wire should connect to the stove neutal, one
hot wire to the stove and one to the light.
3. be careful
Posted on Jul 06, 2008
  • 3940 Answers
SOURCE: GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Posted on Aug 31, 2008
How to use a ge electric oven Have no Manuel and can't figure it out
supply a model and serial number and a manual may be located for you.
Aug 21, 2017 | GE Microwave Ovens
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
Microwave all works,but does not heat.
Seames your magnetron is dead (device that produces the microwaves) or could be a fuse (be cearful when opening electric appliances), if it's the magnetron i'm sorry to tell you it's almost as expensive as a new microwave...
Jan 04, 2011 | GE JVM1850 1000 Watts Microwave Oven
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
We purchased a used GE gas range with sealed burners and self cleaning oven. We are trying to find the model and serial numbers for it. They only numbers we can find are inside the oven door on the side...
How to find the MODEL NUMBER
  • Look for a silver or white label as shown in the drawing below
  • Zeros and ones often look like the letter "O" or lower case "L"
  • Model numbers from owner's manuals are often incomplete or incorrect
Sep 28, 2010 | GE Kitchen Ranges
My electric GE oven self clean lever will not open.It is an older stove that was present when I purchased the house. The lever is stuck in the locked position. How do I open it? thanks dave
You have to manually open it by hand. Since you did not provide a model number I cannot tell you the correct way to do this. need the mod. number
Mar 25, 2010 | GE Ovens
Replacement oven racks
The rack can be purchased from GE online or over the phone the part number is WB48X73 cost is $99.75
Feb 25, 2010 | GE JKP27 Electric Double Oven
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
192 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
