Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
I chang hard drive .imoved all cards . my computer open v
Download very slow
  • 158 Answers
If your hard disk is IDE then use 80-Conductor Cable for fast speed. If your hard disk is SATA then you just download and install the latest driver of your motherboard by which many problem can be solved including your hard disk transfer rate.
If this step is not helpful then please try to format your system and then install the latest driver.
Posted on Feb 25, 2009
How to fix a slow computer
remove / uninstal any programs not in use
defrag the hard drive
add extra ram card
replace the hard drive with a solid state hard drive ( no disc to slow down)
talk with a computer repair shop as to upgrading components / mother board to faster chip
Aug 01, 2016 | Dell Inspiron 1545 Black Intel Celeron 900...
Registry usb
Yes, transferring data files from your expansion drive into the computer or from the computer into the expansion drive can make your computer run slowly.
If it's music and/or movies you are transferring back and forth it's simply because the computer is using most of the processor speed and memory to do it. That's why when another program or the internet is opened your computer will appear to run slowly.
If it's just slow in recognising the contents of your expansion drive it may be due to the age of your computer.
Alternatively it may be that your computer and/or expansion drive is fragmented and has registry errors. Both of these will cause - can cause - your computer to appear slow to load.
You can defragment your hard drive from within the computer. Using Windows XP, open 'my computer' andright click on the 'C drive icon' icon and then choose TOOLS. Open the defragmenting software and let it defrag the hard drive.
To fix registry faults search for and download some free software called free Windows registry repair. http://download.cnet.com/Free-Window-Registry-Repair/3000-2086_4-10606555.html
When downloaded, run the registry fixer by opening the program and click on 'scan'. Wait until the scan is complete and click on 'fix'. Job done...
Jun 09, 2013 | Seagate Expansion Computers & Internet
My system is running slow
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 22, 2013 | Computers & Internet
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
My dell optiflex system started acting slow. OS installed is windows 7, Ram - 4GB usable - 3GB. i re-installed the OS using the re-installaation CD provided by DELL but found no improvement. i woould...
Test the computer's Hard Drive. There are a lot of reasons you might want to test your hard drive for problems. One of the major reasons to perform a test would be if your hard drive is making strange noises. This can often be a sign of a failing drive, something a test can point out.
If the problem is a software issue (virus or too much software installed on the PC) running a System Recovery should have fixed the problem. Try running a test on the computer's Hard Drive. A failing Hard Drive causes slow performance (slow boot, slow computer performance, programs takes too long to load or will not laod at all). And another indicator that the Hard Drive is failing is clicking noises. If you hear clicking noises, backup your files as soon as you can.
You can use free Hard Drive diagnostic tools what can be downloaded from the internet. One of them is Seagate Seatools.You can download it from here - click this link
SeaTools for Windows can perform several basic tests that can help determine the health of your hard drive. Your available hard drives and tests are easy to see when the program opens and can be ran with just a few clicks of the mouse.
Hope this help. Goodluck!
Apr 07, 2011 | Dell OptiPlex 780 DT/ 780 MT/ 780 SFF...
Hi, my brother has a computer with 20gb hard drive, 248mb ram and a amd duron 850mhz processor and the computer is really slow. if i add more ram and change the hard drive to a bigger one, will the...
of corse it will be much faster, **** the speed will be limited, because the cpu is slow, actually it depends on what do u want to do on it?
windows xp will work flawless if u changed ram and video card....
May 11, 2010 | Dell Dimension 3100 PC Desktop
When I swith on the computer,sometimes it can't open,thesystem can run but no visuals.the moniter shows orange light.it is very slow also.
the video (visuals) issue could be a video driver issue.
assuming that you do get something on the screen when you turn the computer on, try to to start your computer in safemode by pressing f8 severval times after you get the first screen, you should see advance startup options. select safe mode and attempt to install an updated video driver (which one depends on your video card manufacturer and model number).
if you don't get any video at all you video card may need to be replaced.
slowness
this is cause by memory wear out or (most likely) malware, now.. you need video and you need to be able to boot into your computer to run some tools that would clean up your system. slowness could also be caused by an old hard drive, if this is the case is better to first get all your data out into a removable hard drive, and replace the hard drive and resintall the operating system.
post back if you were able to get boot up if you have further questions.
Apr 23, 2010 | Intel Computers & Internet
Slow for open file at freehand mx 11
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
May 18, 2009 | Macromedia Freehand MX 11 for PC - Upgrade...
I have an AMD Sempron which I was told came with 40GB. My computer has been running slow and acting strange. When I went to My Computer and clicked on properties i discovered the following: Used Space 36.4...
Mar 17, 2009 | Samsung SpinPoint SP6003H (SP-6003H) 60 GB...
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
