Question about Sony PlayStation 2 (PS2) Console
Numero de default del control parental del ps2 o como resetearlo
Para poder ver todos los titulos aun para mayores de edad
  • davlydavly Jan 06, 2009
    gracias si funciono perfectamente asi como lo puso exactamente
  • Anonymous Mar 15, 2014
    cual es la clave del control parental
  • 3 Answers
I don't know how to tell you in spanish but this is how you do it Step 1
Turn on your PS2 and choose the menu screen where you would normally enter the password. Instead of entering a password, go to the DVD setup menu. Go to "custom setup" and choose "parental controls".
Step 2
When you are asked for the code or password, press the select button on your controller and enter the number "7444". Now set the parental lock to "off".
Step 3
Press "reset" on the front of the game console to save your settings. When the system reboots, you should be able to view your previously censored games or DVDs. You will also have the opportunity to choose your own password, allowing you to turn the parental lock on and off, either manually or automatically by game or movie ratings.
I often recommend that the parents of older children should regularly reset the password in order to prevent "hacking". Also, try to choose a password that could not be guessed easily. Often, a combination of both letters and numbers works best, as the laws of statistics dictate that more choices equal more failed attempts at cracking the code. Unless your child is exceptionally persistent or lucky, boredom will win out before they guess the correct code.
Posted on Dec 17, 2008
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Jan 24, 2011 | LG Studioworks 552V 15" CRT Monitor
Como programar un control de dish
Hola, mi nombre es Mayra Diaz con DISH Nerwork. Primero q todo muchas disculpas por los problemas que le a causado nuestro equipo. Porfavor si me puede dar el numero de su recividor de DISH Network. Para poder darle la instrucsiones correctas en como programar su control. Gracias que tenga un buen dia.
Dec 13, 2010 | DISH Network IR Remote Control
Buenos días, Tengo un Imac con sistema Mac OS X 10.6 Snow Leopard y un HP Scanjet 4470c Como podría solucionar el problema que el Scanjet me funcione con el MAC, no hay manera...
Hola usted debe poder utilizar el conductor para MAC OS 9 para trabajar con su sistema que yo han buscado su explorador de los caballos de fuerza en todos los sitios del MAC y los sitios del HP pero ninguno ofrece los conductores para su específicamente, ellos no hace uno hasta ahora sino intenta éste puede trabajar esperanza éste ayuda a apesadumbrado para la mala traducción
Jul 28, 2010 | HP Scanjet 4470c Flatbed Scanner
Como puedo ordenar la placa del power supply mi numero es 571 5025217
ve a www.shopjimmy.com ahi tienen muchas placas de akai. Pero antes de comprarla chequea todos los filtros de 1000mf-16v y 470 mf-16v . si los ves que estan como explotados arriba cambialos y ponlos a 25v, espero esto te ayude.
Jun 22, 2010 | Akai LCT3285TA 32 in. LCD Television
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Urgente¡¡¡¡¡¡¡¡¡¡bios de mother m748lmrt
QUE NUMERO DE BIOS TIENES EN ESTE MOMENTO
ESA INFO ES LA MAS IMPORTANTE PARA PODER AYUDARTE
DEBES FIJARTE EN EL NUMERO DE PC BOARD
(ES UNA ETIQUTE QUE DICE : VER:XX)
Y AL INICIAR, TE METES EN LA BIOS Y TE FIJAS QUE VERSION ES LA QUE TU TARJETA LLEVA.
Jul 19, 2008 | Intel Motherboard
Sony PlayStation 2 (PS2) Console Logo
100 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
