Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
I need to install a network & print cards to my IR3300 copier. I does have a FAX card but not printer or network. Where can I buy these and how do I configure them once installed?
  • 168 Answers
You need 2 thing the network board and the print boot rom N chip. not to hard to put it but you will need a canon tech with system software to flash the machine with the new items in it.. if you still want to buy it try 1 931 269 6601 southeastern wholesale they usually have some
Posted on Dec 17, 2008
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
How do I install Casette Feed Roller Kit
It's wery simple actually.Just take out the paper cassetes,open the right door and you remove the roller with one move,just push the plastic pin and pull the rooler of the axe
Sep 26, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How can I better the print quality of Cannon IR3300
How many copies drum made?Maybe you have to change it.Clean the optic mirrors platten glass,transfer roller...
Jul 31, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
HP Laser Jet 4700 network card
HP LaserJet 4700 printer comes with inbuilt network card so you don't need to install another network card. If you want to but network card for your PC then go for 100/1000 Mbps network card.
Regards
Ashly
Feb 03, 2010 | HP LaserJet 4700 Printer
What do I need to get my Copystar cs-2030 on a network in order to scan and print? Is there a network card that needs to be installed?
you need a print system k... print card... and a scan system a card...call a kyocera dealer... they will also network it for you... for the price off those two you might be able to buy a km4035 with those two options installed and pay a local tech to network the copier...
Dec 16, 2009 | Copystar CS-2030 Copier
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
My ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
Jan 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Computers & Internet Logo
777 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
