Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses
Exposure number in Canon does not change
The remaining exposure number in Canon Rebel (using Compact Flash card) does not change as you take more pictures. Using a 4 GB SanDisk Ultra II card the exposure number remains at 999. Other cards, e.g. same brand but only 2 GB, the numbers do change as they should. Any suggestions?
  • 40 Answers
Due to the age of the camera, the Ultra 2 CF card may be using a different architecture than your other CF cards. In other words, the card is incompatible with the camera.
One other problem may be that the camera is not designed to recognize a card which is of a larger capacity.
As I cannot find the 300D on Canon's site it is difficult to find exact specifications as to the abilities of the camera, as to what type of CF card it will accept, what the largest capacity it will accept, etc.
A more fixable problem would be either that the card is not formatted properly - which may be possible through the camera itself. Please try to navigate the camera's menu to find a format option. If not, you can insert it into a CF card reader and attempt formatting it that way. Please see Here for formatting through a camera.
Also, try Here for yet another possible explanation of your problem, as #6.
If the camera is meant to take the capacity and type of CF card, and is not damaged, the only other explanation is that it is write-protected. As I do not know the exact features of your CF card, I cannot say whether or not it has a manual write-protection switch. If it does, it would be a small sliding piece of plastic or metal on the side of the card which toggles the write-protection feature. It may also be write-protected as a file system, in which case you will need to format it.
If the card refuses to format due to a write-protection, you will need to remove the write-protection from the card first and then format it.
The following picture shows a CF card with a write-protection switch on the left hand side.
If this proved helpful, please rate. If you need further assistance, please come back and I will attempt to provide further help.
Thank you and take care,
- Dshack.
Posted on Dec 16, 2008
  • Dshack
    Dshack Dec 16, 2008
    Grantson's solution follows the same line as the 5th paragraph linking and pointing to an explanation at entry #6.
    Grantson's solution is most probable, and you would need to raise the quality of the shots you take or take enough pictures to lower the gauge down to a point where it would show below 999.
    Hopefully this is the cause.
    Problem Solver:
  • 5 Answers
With a 2gb compact flash in my canon 300D set to the highest image resolution with no compression I can fit 620 images on the card at iso100 it follows that the 4gb card would fit somewhere in the region of 1200 pictures.
if i set the image size to small with compression a 512MB card will fit 500 images and the 2GB displays the same symptoms as your 4GB card.
The display will show 999 as this is the highest number it can show until there are fewer than 999 exposures remaining at your current settings :)
also tested this on a Canon 30D to find the same thing happens
then with a canon powershot G9
set to 5MP on fine or normal quality a 2gb SD card holds well over 1000 images
Nothing to worry about just plenty of space :D
To change the "exposure compensation" it's saying
When you change the exposure compensation setting, the camera will change the aperture, the shutter speed, or the ISO depending on the mode you're in and the shooting situation. That's what "compensation" means.
Dec 30, 2010 | Canon Rebel XT / EOS 350D Digital Camera
White balance issues on canon rebel xs
Its exposure problem you need to take canon service center and tell them to adjust exposure and shutter speed.
Jul 31, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
With my Canon EOS digital rebel xti i have the
I think it got exposure problem so need to adjsuted exposure and shutter speed or need to replace either top cover or finder unit i recommend to repaire with canon authorised centrre only.
Jul 02, 2010 | Canon Digital Rebel XTi 10.1MP Digital SLR...
I shot 200 pics w/Canon EOS rebel XT 8mp camera on a new San Disk Ultra 4GB card. All pics look like flash did not work. It was working and I've shot hundreds of pics in same place, same lighting, using...
The CF card has nothing to do with the information that is sent to it. It is just a recordable medium that stores what the camera sends to it. There is some other problem with the settings of the camera that caused the photos to be underexposed. Do you use RAW mode for capture of the images? If you do then the Canon RAW conversion software can batch process the photos to correct the exposure.
Apr 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Overexposed, display is stuck
Just checking. Have you checked the exposure compensation. I apolagise if this is too obvious.
Regards, Tim H
Jan 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Dark exposures
This could be many things. If indoors, use higher iso setting and/or use the flash. Make sure exposure compensation is set to 0, or raise it. Use one of the automatic programs and let camera pick shutter speed and aperture. In manual mode, pay attention to exposure value in viewfinder, and avoid using higher apertures unless outdoors in bright sun (f16, f22, etc) the higher this number the less light is allowed to camera.
May 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Digital slr camera
You'll need to use your camera in manual mode.
If you want the subject sharp, but the background blurred, use a large aperture and high speed exposure. This will reduce the focal length.
Remember that a large apertures are often used for night shots because they allow more light through the lense. A fast exposure will prevent the shot from being over exposed if you are taking it in daylight.
Flash photography is not recommended for the effect you are after.
Mar 24, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Digital Rebel XT, exposure
Use the bracket exposure method. or read the apeture off then up a stop.
Jun 05, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses Logo
371 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
