Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Frigidaire refrigerator is not cooling
This is a top freezer Frigidaire unit model# FRT8G6FMB3 which is 2 years old. The lower compartment of the unit is not cooling but the freezer is working just fine. I thoroughly cleaned the 'undercarriage' of the unit as recommended by the manual. Inside the lower part of the unit, I removed the temp control cover and noticed ice had formed in the two channels leading from the freezer to the fridge. I defrosted the fridge and re-engaged the unit. The freezer still works but the lower compartment is still not cooling. I noticed that the evaporator fan is not working which I assume blows air into the lower compartment?
  • 4 more comments
  • kurt485 Dec 16, 2008
    I did the manual defrost as you suggested and the freezer is still extremely cold however the lower compartment isn't. This would rule out the 'self defrost' troubleshooting would it not?
    Yes, but I've already defrosted the unit so if the fan froze up, shouldn't it now work properly? Is it possible that if it froze up the fan motor could malfunction?
    Drumbanger.....that's what I feared. Would you happen to have a part # that I can use to get the proper part?
    So I need the entire kit and not just the fan?
    Thank you all for your help!
  • kurt485 Dec 19, 2008
    It was the evaporator fan motor which I replaced and it did the trick. Thank you all for you help!
  • Frigidaire Master
  • 8,220 Answers
The fresh food compartment gets its cold air from the freezer compartment via that evaporator fan. I would say it either needs oiling or replacement.
Make sure you have a clear defrost drain. If your drain is stopped up the defrost water will pool up between the freezer and fresh food compartment and make a big fat slab of ice. Result. Good freezer,poor fresh food cooling.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
  • Dan Webster
    Dan Webster Dec 16, 2008
    I suspect you have a blocked defrost drain. Evaporator fan should be running also.
    Genius:
  • 1,199 Answers
Ok it sounds like your blower fan froze up remove fan cover unplug fridge and hold a blow dryer to wher the fan bkade blows cold air! check to mack sure ice is not built up around of fan blade (if ice is there melt and remove (it is rare that a fan blows out but it is very common for them to get ice on them and freezs up!
    Sergeant:
    Novelist:
  • 327 Answers
ooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
  • 1 more comment
  • classyexpert Dec 16, 2008
    u can get the required parts at
    www.repairclinic.com
    just check ourt this and select the proper modelnumber of the unit and required part and it will be shown with proper picture and its on going rate at present .u can order they will provide u.
    yes.u r right.u will definately need the kit.
    thank u too for keep all us updated.
    thanks.
  • 275 Answers
Add freon
Posted on Dec 17, 2008
    Genius:
  • 1,061 Answers
I believe your compressor may be going bad.RICHARDM69
    Novelist:
  • 59 Answers
Hi kurt485 -
I think your instinct is absolutely right - that evaporator fan should be running. If it's not, then the motor that operates it probably needs to be replaced (I don't think it has anything to do with the freezer because, as you indicated, the freezer is working properly). The part number for your evaporator fan motor is 240369702.
For your reference, the parts list and schematics for your refrigerator can be viewed at the following web address - note that the evaporator fan motor is No.13 in the list on page 5.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/5995479010.pdf
You can locate a parts distributor near you on this page:
http://www.frigidaire.com/support/parts.asp
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
    Master:
  • 479 Answers
It is very much necessary to get whole kit as this in not the minor problem of any fan or any small fuse or any sigle part.that will solve the problem.get the kit and it will help u. thanks.
    Sergeant:
    Champion:
  • 338 Answers
Part number 5303918274 for the evaporator kit
  • Robert Artiaco Dec 17, 2008
    its always best to replace with a kit if it is available.
The top freezer compartment cools but the lower refrigerator compartment does not. Please help.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Frigidaire Refrigerators
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
Standing water in the lower compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
WHERE DO I FIND A REPLACEMENT TIMER DEFROSTER FOR FRTC03L3DS0 ... FRIGIDAIRE MANUFACTURED BY ELECTROLUX ... SMALL REFRIGERATOR WITH FREEZER COMPARTMENT SEPARATE APPX TWO YEARS OLD ... STOPPED COOLING ......
Could you recheck the model number for your refrigerator. The number you listed is for a oven. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Thanks, Sea Breeze
Mar 27, 2009 | Electrolux Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Dec 27, 2006 | Roper RS22AQXKQ Side by Side Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
496 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
