Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
I got new belts but the brush wont turn
The brush on the vacuum wont turn and i just got a new belts. It's a hoover with a wind tunnel. (12 amps) how do i fix it?
  • bikerprinces Jan 06, 2009
    Mine is a Eureka bagless upright and it's doing the same exact thing! Is there something I can check? A short? Maybe a blown clutch? HELP!!!!
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Posted on Dec 28, 2008
  • 281 Answers
Take the brush roller out of the vacuum and hold on to the ends and see if you can rotate the brush.if not then either you need a new brush roller or something is wrapped around the end caps keeping it from turning
Posted on Apr 04, 2009
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
My hoover Wind Tunnel vacuum cleaner's motor spindle keeps overheating. Because of the high temperature, it keeps burning through belts (the big, wide ones). I have taken it in to the vacuum repair shop...
before you toss the vacuum, check that you can turn the brush by hand and that the belt and brush move freely together. It could be that they are bound up, and that in turn causes the spindle to overheat.
Oct 15, 2017 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Aug 06, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
638 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
