SOURCE: fixing a fuel pump on a 1997 oldsmobile aurora
The good news first!!
No need to drop fuel tank!!
Lift carpet from trunk ... just in front & a little to the right of spare wheel well is an access cover. When screws and cover are removed you have complete access to top of tank with pump and sender assembly mounted below a twist off clamp ring. When replacing Delphi fuel pump unit make sure you also replace gasket.
The bad news!!!
New pump unit over $300!!! ... try junk yards.
SOURCE: replacing fuel pump on 1995 oldsmobile aurora
The GM 1995 Aurora repair manual, says to use the access hole under the
carpet in the back right corner of the trunk. You are best to buy a new fuel sender locking nut or ring at the
dealer for about $8.
Forgot to add this - to relieve the fuel pressure, just use the
press the center of valve on the fuel rail (for pressure testing) and a
rag to catch the dribble. Really no big deal.
Make sure disconnect the battery cables too
SOURCE: where is the oil pump located on the 2001
it should be in the oil pan. Drain the oil, remove the bolts, remove the pump, and when re-installing get a new pan gasket or it will leak.
