Computers & Internet Logo
Anonymous Posted on Aug 06, 2012
How can I change the time between auto refreshes?
I am currently using the page linked below, and it refreshes every 8 seconds roughly, doesnt give me enough time to read more than 1 ball and it makes the whole thing very frustration. is there a way to increase time between refreshes please? I love the updates, but i am close to switching to someone elses due to not being able to really read the messages
Shad
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 15, 2013
Shad
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
943
Points
Step 1: Start Internet Explorer if it is not running already. Click on Tools and then Internet Options.
Step 2: In the Internet Options dialog box, click on the Security tab and then select Internet Zone. Click on the button below labeled Custom Level.
Step 3: Scroll down the list that pops up until you find the entry called Allow Meta Refresh. You can see two option buttons below the entry: Disable and Enable. By default, it should be enabled. Disable it and click OK.
Step 4: Click Apply and OK on the Internet Options dialog box. That is it! Your page will no longer refresh automatically anymore, so you will not have to worry about content being updated or changed without your permission.
Although this solves the annoying problem of a web page refreshing every few seconds, let me make it clear that meta refresh is important. Many websites use it to direct the visitors to the correct web page, though the use of meta refresh is discouraged by the W3C.
Note: The use of Meta refresh by websites is decreasing day by day and is being replaced by JavaScript functions or HTTP redirection headers. This method may not work for sites using JavaScript.
Banjade
Level 3:
  • Master 430 Answers
  • Posted on Aug 06, 2012
Banjade
Master
Level 3:
Answers
430
Questions
Helped
88090
Points
1382
You can't do anything about this website because is design in such a that it keeps on updating every time.
To read full then you can try the Full Score board.
On and off
Turn off the Auto start function by holding it down 6 to 8 seconds. Refresh the startup and go from there. See page 17 in the manual.
The gateway is currently measuring your network connection.Accessing this web page might have an effect on the measurement. This page will refresh shortly.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
[email protected] ka new passward
Please follow the below step for change password or new password. but if you forgot password then only open this link http://edit.yahoo.com/forgot and do as per instruction otherwise follow the below step for how to change password.
stpe1 : Open yahoo.com
Step 2: click on sign in
step 3: find top right side of the page hi,xyz (hi with username)
step 4: there is you can see a little arrow (dropdown list)
step 5: select (click on) account info
step 6: find change password
step 7: first feed your current password
step 8: feed your new password for two time
thanking you
davevipul197
Jan 04, 2011 • Yahoo Mail
I have an LT Series Gateway Netbook. I am trying to connect to a Sony VPL-AW15. I am using a Sony STR-K7000 A/V receiver. The projector is giving the error message "Frequency out of range". I have...
HEy try changing the refresh rate
1. Right click on a empty space on the desktop and click on Screen Resolution. (See screenshot below)
2. Select the monitor Display you want to change the screen refresh rate for. (See screenshot below step 3)
NOTE: You will only be able to select a different display if you have more than one monitor connected.
3. Click on the Advanced settings link. (See screenshot below)
4. To Change Only the Screen Refresh Rate -
A) Click on the Monitor tab. (See screenshot below step 4C)
B) Select an available Screen refesh rate from the drop down menu.
WARNING: It is recommended to leave the Hide modes that this monitor cannot display box checked to prevent possible damage to your monitor.
C) Click on OK. 143d1229784117t-screen-refresh-rate-display-settings-monitor_settings.jpg
D) Go to step 6.
5. To Select from a List of All Display Modes -
A) Click on the Adapter tab, and on the List All Modes button. (See screenshot below) 7331d1238960189t-screen-refresh-rate-display-settings-adapter1.jpg
B) Select the display mode with the screen resolution, color depth, and screen refresh rate that you want to use, and click on OK. (See screenshot below)
NOTE: It is recommended to use a native screen resolution with a True Color (32-bit) color depth. 7332d1238960189t-screen-refresh-rate-display-settings-adapter2.jpg
C) Click on OK. (See screenshot below step 5A)
6. Click on Yes to confirm the screen refresh rate change. (See screenshot below)
7. Click on OK. (See screenshot below step 3)
1helpful
2answers
How do i change my homepage to Yahoo?
Bring up the browser window and let it load to whatever page it is set for. Once it loads, click up in the address bar and type in www.Yahoo.com and click enter. When the Yahoo screen loads, click on the "Tools" column and scroll down to "Internet Options". In this window the first area you see is the homepage tab. Click on "Use Current", this will make the current page your home page, which is Yahoo. Click apply and OK.
10helpful
Setting up explorer 8 to auto refresh
Maybe this will help "http://download.cnet.com/AutoRefresher-for-IE/3000-12512_4-10293579.html" download it and use.
1helpful
DOES PLASMA TV HAS 120HZ AUTO MOTION PLUS
This particular model has a 60Hz refresh rate. At this point there are no broadcasts or video sources outside of special labs that can generate enough data to produce a refresh rate of 120Hz. Expect this to become available in a year or so. Please realize that the human eye can not see changes faster than about 30 frames per second. The current standard refresh rate of 60Hz is twice that. The only change you could see (unlikely) would be a slightly smoother flow for fast moving scenes. Typical movement on the screen will not likely see a difference.
Dan
1helpful
Refresh Database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Changeing the refresh rate
You can download the manual and view it on this Acer web page. The monitor should adjust itself to the refresh rate provided by the converter box...but you can experiment with the picture clock settings described on pages 9 and 10.
Top ESPN EMEA Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an ESPN EMEA Computer and Internet Expert? Answer questions, earn points and help others
