Question about Whirlpool 5"x36" White Bathroom Drop-in Bathtub Spa Jet
Motor powor cord has only 2 prongs--no ground prong
Is that OK? I am about to run the power line to the tub.
Model data hard to read. There are 2 numbers.
FZM1625963
J0032RAJ
Thanks,
Rich
  • rich0705 Dec 17, 2008
    It wasn't manufactured with one. I have tried to contact the manufacturer, Whirlpool, but after 6 different phone numbers have
    only been able to leave a "will call back" message...still waiting.
  • compuwayne May 11, 2010
    Is the third prong missing or are you saying it wasn't manufactured with one in the first place?
  • 35 Answers
If it wasn't manufactured with one, it's double insulated and doesn't require one by design.
Posted on Dec 18, 2008
Hy My Beko f freezer compressor gets very hot (can hardly touch it). Unable to source replacement ptc switch although the unit still restarts, it looks burned! Prob causes? Any suggestions please?
TRY THIS
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, sometimes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Feb 11, 2017 | Beko Refrigerators
How do the wires get reconnected to the starter relay on tfx26apdaww
see pics To check ur compressor with multi meter:
Jan 13, 2016 | GE Refrigerators
Started to be noisy when compressor starts up. Tried cleaning dusting motor area including fan. Seemed quieter but becoming noisy again
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Mar 28, 2015 | Refrigerators
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
Want to switch electrical cord on a whirl pool dryer. from a four pronge to a three pronge
In most all cases, the 4 prong plug has to lines of power, one line neutral, and finally a ground. The only thing you can do is eliminate the ground. You still need to run a ground wire from the unit to some sort of positive ground for safety reasons. Do not leave the unit ungrounded. You can really get hurt or worse.
Apr 01, 2010 | Whirlpool GEW9200L Electric Dryer
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Mar 24, 2007 | Rainbow 75th Anniversary Canister Vacuum
Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
85 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
