Question about Minolta Office Equipment & Supplies
What does the wrench symbol with the C8 after it mean?
I have followed the direction in the manual to turn OFF the power ON/OFF Switch and unplug unit. Then plug uniy back in and turn ON the power ON/OFF switch. Unit does respond sometimes and when I copy an item it comes out very light even with the slide control all the way over towards the dark setting
  • Everett Lin May 11, 2010
    could you tell me which model, usually the wrench symbol means need PM, (need to replace drum, drum blade, developer,corona wire etc.
  • 469 Answers
C8 is unusually high fuser temp. most likely cause a dirty or damaged thermistor in the fuser. The Fuser fuses the toner to the paper if it is operating out of range it could cause quality issues. but they could be two unrelated problems.
But Check your toner supply and press the toner button on the control panel acouple of times if it has one. you were not specific with the model
Posted on Apr 14, 2009
2004 saturn vue service light on with wrench how do I reset
which service light with wrench their are two of them 01 is inside a car symbol the other is next to an oil container symbol if first on vehicle needs service its also like a check engine this one can turn on for abs-transmission-etc have vehicle scanned for a trouble code --the other is oil change or service reminder both symbols are on page 3-39 and 3-40 of your owners manual the first symbol advises to see a dealer to review the trouble code and page 5-20 explaines how to reset oil change/service light --turn key to on/run position not start and push accellarator 3x and system will reset the following link is owners manual
2004 Saturn VUE Owner Manual
Sep 06, 2016 | 2004 Saturn VUE
What does "wrench" symbol mean in message center?
Wrench means, workshop needed. If it does not come back, no problem. If it keeps coming back, visit a repair shop.
Jul 17, 2014 | 2007 Mercury Mountaineer
My 2006 VW jetta has a symbol of a wrench and it's meaning is not in the manual. What does the wrench symbol mean?
This means that your vehicle requires service. Something is wrong. You can take it to Autozone and they will put it on their diagnostic machine for free. And tell you what is wrong. Usually nothing major. Just needs to be checked out.
PLEASE RATE by checking one of the 4 thumbs ups!
Thanks! Have a GREAT DAY!!!
Oct 19, 2010 | 2008 Volkswagen Jetta
Won't shut off says F1 with a wrench symbol
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 21, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
The dash in my envoy just started displaying two symbols: one is a car with squiggly lines behind it and a wrench besides it and the other is basically the same car w lines but there is a triangle around...
Do you have a button there for putting the car in winter drive? all wheel drive? something to do with the rear end? The squiggly lines means traction, or lack of, and the wrench means fix it. And the triangle means it is on. So there must be a switch someplace next to the shifter that turns something on, having to do with the rear end. Check it out.
Feb 25, 2010 | 2008 GMC Envoy
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
Turned off compaq presario desktop and now it wont turn back on. I used the start menu to shut down. Everytime I press the power button a light flashes over a symbol that looks like a lightbulb. Help
Try the following:
1. If connected to surge protector, make sure it's on. If it is, then...
2. Try plugging computer directly into wall and turn on...if no then...
3. Unplug and plug the power cord back in and then try to turn on...if nogo then...
4. If there's a switch on the back of your pc that has 120/240. Switch it back and forth back from 240 back to 120, turn on again...if no go then...
5. Unplug everything from the back of your pc except power cord, keyboard, mouse, and monitor. Try again. If it still doesn't turn on.. let me know. By chance, has any power outage occured or any change been done to pc since it was last turned on?
Dman
Jan 08, 2009 | HP Compaq Presario SR1123WM PC Desktop
Wrench light is on and odometer shows negative mileage
The negative number means the car should have had it's oil changed that many miles ago. Oil life starts at 100% for new oil & counts down every 10%. At 15% the display will always show, which means it's near time to change the oil.
usersteve83, your oil may have been changed but the timer not reset. Reset the timer as shown...
1. Turn ignition to the "ON" position. (do not start engine)
2. Press SEL/RESET repeatedly until the oil life indicator is displayed.
3. Press & hold the SEL/RESET for about 10 seconds until it blinks then let go of the button.
4. Press the SEL/RESET again for about 5 seconds or until the oil life indicator resets to 100%.
Wrench = Maintenance Minder: Symbol letter & number...
Symbol A - Relace engine oil.
Symbol B - Replace engine oil & filter, Inspect front & rear brakes, Check parking brake adjustment, Visually inpest the tie rods, suspension components,driveshaft boots, brake hoses & line (including ABS), all fluid levels & their conditions, exhaust system, fuel lines & connections.
Symbol 1 - Rotate tires.
Symbol 2 - Replace air cleaner element (dusty conditions every 15K miles) & replace dust & pollen filter (behind glovebox) every 15K miles if mainly dusty or city driving.
Symbol 3 - Replace transmission fluid.
Symbol 4 - Replace spark plugs.
Symbol 5 - Replace engine coolant.
All above are taken from the 2006 Civic EX owner's manual.
Dec 02, 2008 | 2006 Honda Civic Hybrid
Ricoh Aficio 450 copier
Wrench means "call for service" More information may help Ed
Jun 14, 2007 | Ricoh Aficio 450 Copier
152 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
