Question about HP LaserJet 2200D Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
My HP Laserjet 2200dtn keeps printing out blank paper and will not stop printing. Every 2-3 pages it jams in the output tray and then after I remove the jammed paper it continues to just print blank paper. The green light is flashing, but does anyone have any ideas what this means? I tried doing  a cold reset already, but after the attention light comes on it just continues to spew out blank paper.
  • 72 Answers
Sounds like it has a solinoid that is stuck open.
Posted on Jan 16, 2009
HP laserjet printer2200dn it prints a blank paper and the paper comes out slowly what is the problem of this printer.
Try getting a feeder cleaner. It will clean the rolls or get a pressurized air can and use it to blow dust off.
Oct 16, 2012 | HP Laserjet 2200dn 2200 Dn Printer Duplex...
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Nov 20, 2009 | HP LaserJet 1320 Printer
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
I have an hp 4200n that picks up an extra blank page when i print a menu map. the paper (blank page only gets up to the delivery assy past the fuser, no jam error). this happens when i print it from tray...
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Oct 15, 2009 | HP LaserJet 4200n Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Keeps pumping out paper with no immage
Try and download the latest driver software from www.hp.com and install it. This is what it sound like to me, good luck
Feb 17, 2007 | HP LaserJet IIp plus Printer
HP LaserJet 2200D Printer Logo
730 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
