Question about Mitsubishi VS-60803 60" Rear Projection Television
Mitsubishi vs-60803 for the last couple of days my t.v. seems to have a little problem, on th left hand side of the screen I get a red and a green line and 3/4 of the screen looks good. I already tried to align my colors but that didn't work and when you hit factory reset on the menu it aligns the t.v. fine, but when the picture goes back to normal it still shows the same problem. Thanks
    Genius:
  • 1,074 Answers
Greetings from belize take your set to a tech and have him look at it.good luck.
Posted on Mar 23, 2007
Mitsubishi vs-60803 turns relay on board then goes
replace the power relay the contacts are burned and, will not latch.
Jul 22, 2010 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
My 1996 mitsubishi projection tv is out of focus what should i do
looks like the Green , RED and Blue are out of alignment and needs to be sent to the TV repair station for alignment
Sep 18, 2009 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
Green and Blue are stuck as thin shape up the middle of screen
You need to replace both convergence ICs numbers STK392-110 they are located on the far left side attached to the large heat sink. You can get replacement ICs at the following link and they provide free instructions with pictures so you can do the repair yourself in about 45 minutes from start to finish. heres the link.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi vs-60803
You have the typical convergence IC falure that every projection TV encounters at least once in its lifespan. The convergence ICs will both need to be repalce as it will only get worse. if you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Mar 23, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
