Question about Whirlpool LSQ9500L Top Load Washer
Removing agitator on Whirlpool LSQ9500L Top Loading washer
Lost a pin from a blouse in the washing machine, Could it be under the agitator? Apears to need a "very deep" 5/16 socket. Any suggestions?
SOURCE: removing bolt in agitator arm
The bolt unscrews counterclockwise. Hold the agitator by the bottom vanes. If it won',t budge try tightening it first, just a little to break it free.
Posted on Dec 28, 2007
jonniewalker
  • 1031 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
jsrock516
  • 5911 Answers
SOURCE: removing agitator
Sometimes small articles of clothing can manage to get between the inner spin basket and outer wash tub. This is NOT common, however. If this were the case the memory stick you mentioned, would end up lodged in the drain pump. There would be a noticeable noise from the impeller hitting it and it may cause the pump to fail, resulting in drainage problems. More than likely, its right where you suspect it is. To remove the agitator, do the following:
1. Remove the center cap or dispenser from the agitator.
2. Under the cap or dispenser is another plastic cap with a pull handle on it. Lift this cap out by pulling straight up, exposing the agitator mounting bolt.
3. Loosen the agitator bolt using a socket and ratchet. Once removed, grasp the entire agitator assembly by the bottom flanges and lift straight up. The entire agitator should come out.
NOTE: When reinstalling the agitator make sure you DO NOT overtighten the mounting bolt or it can cause damage to the agitator and restrict the movement. Good and "snug" is the rule of thumb.
Searspartsdirect.com has an excellent exploded view diagram of your agitator and components if you need a good reference. Just type in your COMPLETE model number and look under the "Agitator, Basket and Tub Parts" heading.
I hope you find what you're looking for and hope this helps you in some way. If you require additional assistance, please let me know.
Posted on Sep 26, 2008
  • 21 Answers
SOURCE: Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Posted on Jan 19, 2009
SOURCE: Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Posted on Feb 22, 2011
I have a silk blouse caught under the agitator of my Simpson eziset 8.5kg top load washer. does the agitator come off?
They should come off though I am not sure of your machine, they are designed to be changed.
Mar 05, 2016 | Simpson Washing Machines
Does the Whirlpool, top loading lsr6332kq1 have a lint filter?
I will suggest you steps to check whether your washing machine has a lint filter. Follow the instructions below.
1)Turn off the washing machine and open the lid or door if you have a front-loading appliance.
2)Place your hand on the upper lip of a front-loading or top-loading washer tub and feel around the circumference for a flat tab. Pull out this tab, which is the handle for the lint filter. If you cannot find a tab on a top-loading washer, continue troubleshooting.
3)Unscrew the cap on the top of the agitator in a top-loading washer. The agitator is the center cone inside the appliance.
4)Pull the lint filter out of the agitator and rinse under cold, running water to clean.
5)Slide the filter into position as far as it will go. Replace the agitator cap if your appliance uses a lint filter in the agitator.
Mar 28, 2013 | Washing Machines
Kenmore Washer has a blouse caught under the agitator. How do I get it out?
get both hands on the paddle (top end in the machine) and pull down and towards yourself,, and the paddle will come out letting you to take the blouse out
Oct 19, 2012 | Kenmore Washing Machines
I want whirlphool whasing machine with dryer please give the gideline of it and its price my e - mail ID is sabiha_1993@hotmail.com.
Washers are more advanced and stylish than ever before. When you're buying a washer, look for features that make washing easier and more efficient, less costly, and kinder to fabrics. Thanks to advances in technology, it's all possible - and our washer buying guide shows you how.
Washer Types
Feature options, capacity, energy use and style are all factors to consider when deciding between a front- or top-loading washer.
oth top-loading and front-loading washing machines will do a good job of cleaning your clothes. The most significant differences between these types of washers are capacity, energy efficiency, water use, feature options, and style.
Top-loading machines
Traditional top-loading washing machines are available in a wide assortment of models, price ranges and styles. The most basic top-loading washers perform very well and are generally a good value for a no-frills, clean wash. Other top-loaders offer more cycle and temperature selections, spin speeds, and fabric care extras as they increase in price. Overall, top-loading washers are generally less expensive to purchase than front-loading machines, but are slightly more costly to run because they use more water and electricity.
Most top-loaders fill the tub with enough water to cover the clothing, then agitate them to get the clothing clean. Some manufacturers now offer high-efficiency top-loading washers using a number of different technologies. One such technology is the Whirlpool® Calypso® wash plate. Instead of agitating fabrics to get them clean, the wash plate moves them through a shower of concentrated detergent and water. The action is gentler on fabrics; it's designed to provide better cleaning with far less stress to garment fibers. And with the agitator out of the way, the washer has more room to clean bulky items such as comforters and rugs.
Standard capacity for a top-loading washing machine is 12 to 16 pounds per load. The Calypso wash plate model can hold up to 18 pounds of laundry (think the equivalent of 16 pairs of jeans).
Here is a link to some Whirlpool washers for you to look over.
Dec 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washer leaves trash on clothes when finished. has been doing this for some time now. some of the particles resemble dried tree leaves.
It sounds as if there is a soap buildup in possibly a couple of places and it is coming loose then ending up on your clothing. If you changed brands of soap this can happen also. The soap buildup can be under and inside the agitator. It can manifest itself in large calcium type flakes in the washer when it finally breaks down and you see it. You can remove the agitator by opeing the top of your agitator and removing the retaining biolt then lifting out the agitator. Use a putty knife and scrape off the inside of the wash tub under the agitator. Also take the agitator either outside or to the bathtub depending on weather and scrub it clean on the bottom and on the inside of the agitator. If after all of this you still have that same material show up you may have to remove the wash tub itself and clean the outer tub with a putty knife. There is a special tool that locks into the 4 slots of the tub nut used to remove the tub nut. You can buy it at most appliance part centers. Tell them you need a tub nut removal tool for a kenmore / whirlpool top loading machine and they will walk back and get you one straight away. Good luck andI I hope this resolves your problem.
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Anklet is lost in the washer help
Not sure of this model, but on 'most' top load washers the top piece of the agitator will unscrew, pull the agitator up, anklet should be under it if is too big to fit through the holes in the tub. If it isnt there, look for the screen in front of the water pump. Which means either pulling up the top, or removing the back. Good luck
Jun 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Whirlpool LSQ9500L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
