Question about Sony Playstation 3 (40 GB) Console
In a cabinet and getting dusty in vents how to clean?
I have the ps3 in a cabinet with screened front but overheats so i got an external fan and still gets dusty. What is the best way to clean?
  • 133 Answers
Well once my dad bought a little air can used to clean the dust and **** outta your computer and keyboard. If you can manage to find that, it would work very well on your PS3, or if you have a Air compressor, you can use that as well (thats what i use). I heard vaccuums work well too but haven't tried it myself.
but now better things have come up
Note, Only for the 40gb model.
http://www.ps3hax.net/other-misc-tutorials/4079-ps3-fan-test-clean-dust.html
Posted on Mar 24, 2009
Problem screen
If you connect to a External Monitor is it the same? If you boot to Safe Mode is it the same? Has there been ANY damage? Does the Laptop overheat? Need cleaning? Fan, Vents, Heatsink dusty, dirty? Sounds like a Graphics Adapter is going or gone. Have you done ANY graphics updates recently?
May 08, 2013 | Sony Computers & Internet
Computer fan running loud
Clean fan and vents, A dusty computer will overheat and damage the components.
Jan 13, 2013 | Gateway ZX493131e Notebook
Cut out on one occassion & how often does amp need service
Hopefully not often. They are very complicated in design. Keep ALL airflow paths clean and if in a cabinet, give adequate air movement... use a fan if necessary to vent the cabinet. The unit has a string of diodes to adjust the quiescent current in the power amp and if you overheat the unit it will try to protect itself by shutting down.
Jul 25, 2011 | Peavey Pv 2600 Power Amplifier
The overheat safty switch trips after one to two minutes even though the fan is running properly. The unit functions properly with the red light on the front panel comming on while it cools for a few...
If the interior of the heater is dusty and dirty, this may be your problem. Turn off the circuit breaker feed to the heater, remove the front cover and clean the interior with a vacuum cleaner with brush attachment. Pay special attention to the fan blades. Any dust and dirt that the vacuum can't reach can be blown out with a can of compressed air (like you clean a computer with) and the straw nozzle. If you use the canned air, vacuum again after blowing it out. Replace the front cover, turn on the circuit breaker and test the heater. If that doesn't solve the problem, go to the manufacturer's website to obtain parts.
Jan 21, 2011 | Fahrenheat FFH1612 Wall Mounted Panel...
Dryer is extremly hot to the touch, condensation on cabinets and walls in the laundry room it gets so hot in there when dryer is running
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. What is your model number?
Nov 28, 2010 | Electrolux Dryers
My playstation just freezes on start up screen and
hello,
"When the PS3 system freezes and wont play, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
May 30, 2010 | Sony Playstation 3 (PS3) Console
Ps3 overheat
Your PS3 might have a broken fan. If you are using an external fan that attaches to the PS3 than stop, fans like the Nyko Intercooler and Pelican cause more problems with ventillation and may cause the PS3 to overheat. If heat is an issue make sure the system has plenty of room to breath and point a small fan at the console. If thiat doesn't work call Sony customer sopport.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 is freezing up
you can purchase a usb powered external fan that fixes to the back of the ps3 from ebay for less than $30 or 15 gbp.
i think attempting to replace the interior fan will invalidate sonys gaurantee ,if it still is under warranty.
lastly i would suggest the obvious and make sure you have you ps3 out in the open and not in an an enclosed environment like a shelf or
tv/video cabinet.also not on carpet, make sure all the vents are not blocked, i found for me the coolest position to run the ps3 is on its side away from other heat sources like plasma tv,video/dvd/sat/cable players.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Overheat
My geforce 4 cards fan took a dump on me once.Check it for dust. and/ or movement.
You need better air movement through your case. Make sure everything is clean of dust. Get a bigger case fan and also add one in the front of the case if possible.
Dont have anything in back of your case for 2 feet.Or on the sides where there are vent holes...
How old is it, it may still be under warranty. They are good at replacements...
Jan 13, 2008 | Leadtek WinFast A280LE-TD 128 MB GeForce4...
Sony Playstation 3 (40 GB) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
