Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
2 of 4 ceramic rings do not respond to lowering the heat setting
When you switch the ring on and heat is set, say at 4, it goes to full heat and does not respond to the thermostat. Problem now with 2 rings
  • Hotpoint Master
  • 3,463 Answers
You need 2 new temperature regulators fitting.
Quite a common problem..
Thanks
Plz rate solution
Posted on Dec 17, 2008
Every time I switch the rings on my creda starlight cooker they start smoking and trip the electric ?
they are shorting out through the ceramic insulation
get and install new rings
Dec 31, 2016 | Creda Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Zanussi hob can't turn off full power on one ring
the regulator is faulty you will have to fit a new one fairly easy task let me know if you want more help
Apr 17, 2012 | Zanussi Ovens
Electolux ekt6045 one ring only works at a time of the four rings. They all light up one at a time but when you try to put two or more on only the first will heat. There is a setting on the touch panel to...
The EKT 6045 hob must be one of the most complicated to use ever.
Just getting more than one ring to work is a major achievement but it can be done but you have to follow the instructions closely.
If you do not have the instuctions try www.serviceforce.co.uk/pdfs/U28003.pdf
You do not say if all the rings worked ok before. But presuming they have there seems to be a control fault.
Providing yo are following the operating instructions correctly, then it's not something you are going to be able to fix yourself and unless its still under the manufacturers warranty period, with repair call out rates as they are you may be better to budget for a replacement.
Jan 03, 2010 | Electrolux Ovens
Element / burner / hob is overheating on an electric oven
If three of the rings are not responding to adjustment, then I would say yes, you have faulty regulators;It is a fairly straightfoirward job to replace if you know how to access the controls
Dec 05, 2008 | New World E70DOa Electric Double Oven
NEFF Hob
change the relay
Sep 21, 2008 | Ovens
Smeg oven suk92mfx5
ring element has burnt out.
Feb 16, 2008 | Ovens
Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
148 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
