Question about Acer Computers & Internet
I have a single yellow vertical line running down the left side of my computer monitor, nothing has been dropped, and it doesn't appear when other monitors are plugged into the same computer.
    President:
  • Acer Master
  • 1,314 Answers
Booga is right. This indicates a column of pixels on the LCD itself has died. If it's under warranty, the manufacturer should fix it. Otherwise the only fix is to replace the LCD part of the screen itself which would cost more than a new monitor.
Thanks and please take a moment to rate as fixya.
Posted on Dec 16, 2008
  • 54 Answers
Let me guess, its an LCD? Unfortunately this has happened with blue lines to our customers.
Sorry, but chances are you wont be able to do anything yourself, best to take it to where you bought it from (or ring the manufacturer) to get a replacement (if its still under warranty), else you may need to purchase a new one.
The left side of my laptop screen wet all white with red green yellow blue lines running veretical lines running through it. looks like someone spilled paint on it
Vertical lines are usually caused by 2 things, either your graphics card is going bad or your screen is going bad. How you check if it is your graphics card is by plugging it into an external monitor (if you have one).
If the lines still appear on the external monitor then you know its the graphics card going bad, which isn't probably worth fixing these days if you take into account how must laptop pricing has dropped.
I hope this helps.
Best of luck!!
Mar 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
A yellow vertical line is appearing on the left side of my compaque 610 screen... how i can i remove it?
  1. Run the laptop only on battery, if there is no line then check & replace your Power plug & Power adapter.
  2. Connect an external monitor, check if display is coming OK.
  3. If Display is coming then your LCD is faulty & need to replace.
Aug 23, 2010 | Computers & Internet
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Yellow vertical lines on the screen of my DELL inspiron 9300
The pixels are shot - common for lower priced LCD monitors. Once it starts, it will continue. Theres no inexpensive fix for it - time to retire the Compaq
Nov 28, 2008 | Compaq Presario M2000 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Jun 26, 2006 | Gateway EV 700 17" CRT Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
