Question about Rollei Prego DP5300 Digital Camera
Camera freezes when taking picture
I turn the camera on and it boots up fine and then as i take the picture the whole camera freezes and won't respond to anything i push - the only way i can get it to turn on again is by removing the battery and reinserting it. Does anyone know why this is happening?
0 characters
1 Points
Canon eos 600d, takes a picture on turning on and freezes. When I turn off and on again, it takes a picture again and freezes. Cannot access menu or any other button. how do I resolve this issue?
Camera electronics has developed a mind of its won and has gone crazy. You need to have it fixed or replaced whichever is cheaper.
Make sure the battery is good since many newer electronics operate erratically when the battery condition is not up to par.
Jun 13, 2016 | Canon EOS 600D Rebel T3i Digital Camera
Can't flip through pictures screen won't respond
Hello, Camera needs service/repair, Fault with touch-screen.
Dec 07, 2012 | Kodak EasyShare V1073 Digital Camera
My camera used to work just fine with my pc, now my pc won't find the camera when connected with the cord. I also can't delete pictures because the camera freezes up. I also get 'picture e
You should format the memory card, while in the camera. Find the built in utility. If the format fails (try a couple times first) then get a new memory card. Possibly this will help the conectivity issue too, if not try looking in the Disk Management section (Right click My Computer, Choose Manage) See if the camera, connected to pc, is showing there without a drive letter. Right click on it and assignn it a drive letter. Hope this helps.
Dec 07, 2012 | Polaroid i633 Digital Camera
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
Everytime i use the flash on my Fine Pix s1000fd it freezes
Some SD/HC cards will cause this problem.
You need to upgrade the firmware to version 1,05.
Best regards
Peter Schroeder
Sep 22, 2009 | Fuji FinePix S1000FD Digital Camera
Camera is frozen
My camera is frozen and it won"t turn off in less
I take out the batters.
Aug 18, 2008 | Samsung Digimax S630 Digital Camera
Nikon coolpix2100 not turning on
what does the manual say about the Green LED? Take a look through this list
May 20, 2007 | Nikon Coolpix 2100 Digital Camera
Image on the screen freezes and camera won't respond.
I require the software to enable to download pictures for my
finepix fuji f601z
Nov 17, 2006 | Fuji FinePix F601 Zoom Digital Camera
Rollei Prego DP5300 Digital Camera Logo
24 people viewed this question
Top Rollei Digital Cameras Experts
Barbat Nae
Barbat Nae
Jax Planet
Jax Planet
Are you a Rollei Digital Camera Expert? Answer questions, earn points and help others
