Question about Kenmore Elite HE4 Electric Dryer
Calypso top washer has an error of LD
The cycle starts then stops with the error code and it looks like the agitator is getting jammed (not sure)
  • Anonymous Jan 05, 2009
    i need a list of possibles i have checked those conditions an they are clear.
  • Anonymous Mar 14, 2014
    I have an error code of Ld. washer will not complete the last 12 min of the cycle to rinse out.
  • 8,197 Answers
LD is an error code indicating a “long drain”. If the water is not pumped out quick enough, you will get this error code. This model of washer has a revised pump/motor assembly that will improve the performance of pumping the water out. A poor pump out condition could also be caused by a failure of the drain check ball system. This is a chamber of the outer tub located on the lower rear section of the outer tub. If something gets lodged in the inlet or outlet port of the check ball chamber, you will have either a no drain condition or a poor drain condition. This would have to be checked to confirm.
Posted on Dec 18, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
When running wash cycle, the washer stops during initial cycle when water is going into tub. The "Ld" error code comes up on the panel and sometimes it is accompanied by a humming sound. Can not start...
LD is long Drain.
You'll need to crawl underneath and disconnect the hoses to check the traps for obstructions.
Have a pan handy to catch the water.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool calypso
The fault code "LD" indicates "long drain" condition. It's not only if the water drained, but how fast it drained. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If there are broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or a jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
