If it is a double circuit element, then you will only get 110 vlolts across one circuit, and 220 volts across the other circuit..
If however it is a single circuit element, and you are only getting 110 volts, then I would suggest that you have a high resistance somewhere that is stoping it from getting 220 volts.
Hook the element directly to a 220volt supply and check voltage .
Plz rate my solution.
Thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE JRP24 Electric Double Oven
my new contol panel for my ge jrp24 wall oven came with directions to install but they do not show...
(More)
my new contol panel for my ge jrp24 wall oven came with directions to install but they do not show where to connect the gray wire. also the door is now locked and wont open.
